[Swift-user] Do you have any resource for learning about SwiftR?
Lorenzo Pesce lpesce at uchicago.edu
Thu Sep 8 12:00:28 CDT 2011
Tim,
Be mindful that Beagle now has a new ALPS and scheduler. It looks like the new ALPS is behaving differently from the old one. For example, the -N flag -- one MPI per node -- seems to be broken and ignored by ALPS, while perl now seems to be capable of running multiple MPI jobs per node (before there was no way of making it do that or at least we never found one and neither did Cray).
I did not have time to test either because I work someplace else today, so this is just little more than hearsay, I might be able to do it tomorrow. I plan to try to make Rmpi work and then move on from there.
Lorenzo
---- Original message ----
>Date: Wed,  7 Sep 2011 19:36:05 -0500 (CDT)
>From: Tim Armstrong <tga at uchicago.edu>
>Subject: Re: [Swift-user] Do you have any resource for learning about SwiftR?
>To: "Michael Wilde" <wilde at mcs.anl.gov>, "Lorenzo Pesce" <lpesce at uchicago.edu>
>Cc: "Swift-User" <swift-user at ci.uchicago.edu>
>Hi, sorry for the slow response.
>The documentation is up to date and the latest release is the one pointed to.
>I'm going to try and get the new version of R running on beagle - hopefully this will solve the problems we'd been seeing finally
>- Tim
>>Date: Tue, 30 Aug 2011 11:05:33 -0500 (CDT)
>>From: Michael Wilde <wilde at mcs.anl.gov>
>>To: Lorenzo Pesce <lpesce at uchicago.edu>
>>Cc: Tim Armstrong <tga at uchicago.edu>, Swift-User <swift-user at ci.uchicago.edu>
>>Lorenzo,
>>The SwiftR documentation is currently at:
>>  http://www.ci.uchicago.edu/wiki/bin/view/SWFT/SwiftR
>>which also provides a quick start guide at:
>>  http://www.ci.uchicago.edu/wiki/bin/view/SWFT/SwiftRQuickstart
>>Further examples and some performance measurements are at:
>>  http://people.cs.uchicago.edu/~tga/swiftR/
>>And more examples are available with ?SwiftR help once you load the package:
>>> source("http://people.cs.uchicago.edu/~tga/swiftR/getSwift.R")
>>I just built an R-2.13.1 release on Beagle with plain gcc, which I think *should* be runnable in parallel on worker nodes. (Not yet tested though).  This R should be capable of running SwiftR.  Im hoping that Tim cam verify this soon. We'll likely need an additional SwiftR server name and config for Beagle and other Cray systems.
>>We'll try to consolidate the SwiftR documentation in a user guide on the Swift in the future. Tim, can you do a quick check of the documentation to make sure its still correct and that it points to the latest SwiftR package?
>>Thanks,
>>- Mike
>>----- Original Message -----
>>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>>> To: swift-user at ci.uchicago.edu
>>> Sent: Tuesday, August 30, 2011 9:22:51 AM
>>> Subject: [Swift-user] Do you have any resource for learning about SwiftR?
>>> Hi -
>>> I want to run relatively small sized simulations (say at most 50 cores
>>> or so, probably mostly one or two) but many many times over. The
>>> simulations will be coded in R.
>>> Thanks a lot!
>>> Lorenzo
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
>>Michael Wilde
>>Computation Institute, University of Chicago
>>Mathematics and Computer Science Division
>>Argonne National Laboratory
More information about the Swift-user mailing list
