[Swift-user] task parallel MPI
Justin M Wozniak
wozniak at mcs.anl.gov
Thu May 12 12:23:55 CDT 2011
Ok, it looks to me like some kind srun thing: you can look in the log at
the GridExec lines to find out what was passed to your execmpi script.
The -e argument is the executable and the -a argument is the executable
arguments. You may also try to capture more debugging information in the
execmpi script itself.
On Tue, 10 May 2011, Agarwal, Khushbu wrote:
> Here it is.
> Thanks,
> -Khushbu
> -----Original Message-----
> From: Justin M Wozniak [mailto:wozniak at mcs.anl.gov]
> Sent: Tuesday, May 10, 2011 11:47 AM
> To: Agarwal, Khushbu
> Cc: swift-user at ci.uchicago.edu
> Subject: RE: [Swift-user] task parallel MPI
> Ok, I think I see where this is going: can you resend the tgz with the SwiftScript?
> On Thu, 5 May 2011, Agarwal, Khushbu wrote:
>> Hi Justin,
>> Please find the files attached.
>> Thanks,
>> -Khushbu
>> Sent: Thursday, May 05, 2011 3:36 PM
>> Subject: Re: [Swift-user] task parallel MPI
>> Hello
>> Can you post your sites and tc files?
>> Justin
>>> Hi,
>>> I am trying to launch multiple MPI runs( parallel task) within a
>>> single job allocation, but I keep on getting error about task exiting
>>> srun: error: cu01n2: tasks 0-7: Exited with exit code 2
>>> srun: Terminating job step 1546136.4
>>> Here is my swift script. I am not sure what is going wrong, any help is appreciated.
>>> Thanks,
>>> -Khushbu
>>> type file;
>>> file stompIn <"stomp.in">;
>>> file stompOut <"stomp.out">;
>>> file sphArr[] <fixed_array_mapper;files="sph.in.1, sph.in.2">; int n
>>> = 2;
>>> (file stOut) runStomp (file stIn) {
>>> app {
>>> stomp @stIn @stOut;
>>> (file s[]) pg (file stOut, int num) {
>>> app {
>>> pg @stOut "sph.in" num;
>>> (file output) runSph (file input, int num) {
>>> app{
>>> mpi @input @output num;
>>> stompOut = runStomp(stompIn);
>>> sphArr = pg(stompOut, n);
>>> int list[] = [1,2];
>>> foreach i in list
>>> file sphOut <single_file_mapper;file=@strcat("sph.out.",i)>;
>>> sphOut = runSph(sphArr[i-1], i-1); }
>> Justin M Wozniak
Justin M Wozniak
More information about the Swift-user
