[Swift-user] task parallel MPI
Agarwal, Khushbu
Khushbu.Agarwal at pnnl.gov
Tue May 10 14:45:41 CDT 2011
Here it is.
-Khushbu
-----Original Message-----
From: Justin M Wozniak [mailto:wozniak at mcs.anl.gov]
Sent: Tuesday, May 10, 2011 11:47 AM
To: Agarwal, Khushbu
Cc: swift-user at ci.uchicago.edu
Subject: RE: [Swift-user] task parallel MPI
Ok, I think I see where this is going: can you resend the tgz with the SwiftScript?
On Thu, 5 May 2011, Agarwal, Khushbu wrote:
> Hi Justin,
> Please find the files attached.
> Thanks,
> -Khushbu
> Sent: Thursday, May 05, 2011 3:36 PM
> Subject: Re: [Swift-user] task parallel MPI
> Hello
> Can you post your sites and tc files?
> Justin
>> Hi,
>> I am trying to launch multiple MPI runs( parallel task) within a
>> single job allocation, but I keep on getting error about task exiting
>> srun: error: cu01n2: tasks 0-7: Exited with exit code 2
>> srun: Terminating job step 1546136.4
>> Here is my swift script. I am not sure what is going wrong, any help is appreciated.
>> Thanks,
>> -Khushbu
>> type file;
>> file stompIn <"stomp.in">;
>> file stompOut <"stomp.out">;
>> file sphArr[] <fixed_array_mapper;files="sph.in.1, sph.in.2">; int n
>> = 2;
>> (file stOut) runStomp (file stIn) {
>> app {
>> stomp @stIn @stOut;
>> (file s[]) pg (file stOut, int num) {
>> app {
>> pg @stOut "sph.in" num;
>> (file output) runSph (file input, int num) {
>> app{
>> mpi @input @output num;
>> stompOut = runStomp(stompIn);
>> sphArr = pg(stompOut, n);
>> int list[] = [1,2];
>> foreach i in list
>> file sphOut <single_file_mapper;file=@strcat("sph.out.",i)>;
>> sphOut = runSph(sphArr[i-1], i-1); }
> Justin M Wozniak
Justin M Wozniak
Type: application/x-compressed
Desc: swift-log.tgz
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110510/c6e771d8/attachment.bin>
More information about the Swift-user
