[Swift-user] determining unmapped paths
Mihael Hategan
hategan at mcs.anl.gov
Fri Mar 25 03:41:28 CDT 2011
On Thu, 2011-03-24 at 22:51 -0500, Michael Wilde wrote:
> Possible a mismatch between an external mapper's output and the object
> that its mapping? I.e., wrong dimensionality, or a structure field
> mismatch?
> Im guessing [3] in this case was the string returned by the mapper,
> but Im not sure. (I say that based on the many reports of similar
> errors in the pas on the list, some from you, Allan).
[3] means whatever array you had, the third element in it. It's not a
string, it's a type "path" (though one can convert certain classes of
strings to such type paths by virtue of the fact that one ultimately
expresses such things in a textual language).
More information about the Swift-user
