[Swift-user] determining unmapped paths
Allan Espinosa aespinosa at cs.uchicago.edu
Thu Mar 24 23:23:43 CDT 2011
Well I have something like
type file;
string arrays[] = readData('afile');
file data[] <array_mapper; files=arrays>;
2011/3/24 Mihael Hategan <hategan at mcs.anl.gov>:
> This looks like an internal problem. Mappers should be two way
> functions, so they should be able to map all things returned by
> existing(). If you call D the subset of the set of swift data for a
> mapper and F corresponding subset of filesystem objects, map is a
> function from D to F, while existing returns a collection of objects in
> D. So theoretically map on each element of that collection should work.
> In this case the object in D is [3], which indicates that we are
> probably talking about an array mapper. Could you tell me which one it
> is? And also what files you are trying to map with it.
> Mihael
> On Thu, 2011-03-24 at 16:28 -0500, Allan Espinosa wrote:
>> I'm trying figure out where in my workflow is causing this problem:
>> 2011-03-24 16:23:50,485-0500 WARN  FlowNode Ex098
>> java.lang.IllegalStateException: mapper.existing() returned a path [3]
>> that it cannot subsequently map
>>         at org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:129)
>>         at org.griphyn.vdl.mapping.RootArrayDataNode.checkInputs(RootArrayDataNode.java:67)
>>         at org.griphyn.vdl.mapping.RootArrayDataNode.innerInit(RootArrayDataNode.java:53)
>>         at org.griphyn.vdl.mapping.RootArrayDataNode.handleClosed(RootArrayDataNode.java:80)
>>         at org.griphyn.vdl.mapping.AbstractDataNode.notifyListeners(AbstractDataNode.java:583)
>>         at org.griphyn.vdl.mapping.AbstractDataNode.closeShallow(AbstractDataNode.java:396)
>>         at org.griphyn.vdl.mapping.ArrayDataNode.closeDeep(ArrayDataNode.java:51)
>>         at org.griphyn.vdl.karajan.lib.PartialCloseDataset.function(PartialCloseDataset.java:79)
>>         at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:68)
>>         at org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java:29)
>>         at org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java:20)
>>         at org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java:63)
>>         at org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java:139)
>>         at org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java:197)
>>         at org.globus.cog.karajan.workflow.events.EventBus.start(EventBus.java:104)
>>         at org.globus.cog.karajan.workflow.events.EventTargetPair.run(EventTargetPair.java:40)
>>         at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
>>         at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
>>         at java.util.concurrent.FutureTask.run(FutureTask.java:138)
>>         at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
>>         at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
>>         at java.lang.Thread.run(Thread.java:619)
>> It doesn't specify which data object it crashes on so i'm quite
>> clueless at this point.
>> I'm using the latest trunk
>> any particular log4j class i should be enabling to debug?
More information about the Swift-user mailing list
