[Swift-user] Swift Coasters on OSG
Allan Espinosa aespinosa at cs.uchicago.edu
Thu Mar 10 14:30:07 CST 2011
Oh ignore that.  (just saw your start_services.sh script)
2011/3/10 Allan Espinosa <aespinosa at cs.uchicago.edu>:
> Errr.  I think that was my fault.  I hardwired port numbers for
> coaster services and i'm running a coaster service at the moment.
> Clearly it needs to be fixed.
> -Allan
> 2011/3/10 Ketan Maheshwari <ketancmaheshwari at gmail.com>:
>> Mihael,
>> Yes, in fact sites.xml was actually missing. May be that is the reason for
>> the error.
>> However, Now, when I try to restart the coaster services using the attached
>> start_services.sh script, I get the following error stack:
>> Error starting coaster service: Address already in use
>> java.net.BindException: Address already in use
>> at java.net.PlainSocketImpl.socketBind(Native Method)
>> at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365)
>> at java.net.ServerSocket.bind(ServerSocket.java:319)
>> at java.net.ServerSocket.<init>(ServerSocket.java:185)
>> at
>> org.globus.net.ServerSocketFactory.createServerSocket(ServerSocketFactory.java:114)
>> at
>> org.globus.net.ServerSocketFactory.createServerSocket(ServerSocketFactory.java:68)
>> at org.globus.net.BaseServer.<init>(BaseServer.java:84)
>> at
>> org.globus.cog.karajan.workflow.service.GSSService.<init>(GSSService.java:63)
>> at
>> org.globus.cog.abstraction.coaster.service.CoasterService.<init>(CoasterService.java:74)
>> at
>> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.<init>(CoasterPersistentService.java:34)
>> at
>> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:98)
>> Perhaps, I need to kill the previously started service but couldn't figure
>> how.
>> Thanks,
>> Ketan
>> On Thu, Mar 10, 2011 at 12:01 PM, Mihael Hategan <hategan at mcs.anl.gov>
>> wrote:
>>> It probably means your sites.xml is empty. Can you post it?
>>> Mihael
>>> On Thu, 2011-03-10 at 09:03 -0600, Ketan Maheshwari wrote:
>>> >     Submit workflow sleep.swift.
>>> > I get error message: No service contacts available.
More information about the Swift-user mailing list
