[Swift-user] Swift Coasters on OSG
Allan Espinosa
aespinosa at cs.uchicago.edu
Thu Mar 10 14:28:47 CST 2011
Errr. I think that was my fault. I hardwired port numbers for
coaster services and i'm running a coaster service at the moment.
Clearly it needs to be fixed.
-Allan
2011/3/10 Ketan Maheshwari <ketancmaheshwari at gmail.com>:
> Mihael,
> Yes, in fact sites.xml was actually missing. May be that is the reason for
> the error.
> However, Now, when I try to restart the coaster services using the attached
> start_services.sh script, I get the following error stack:
> Error starting coaster service: Address already in use
> java.net.BindException: Address already in use
> at java.net.PlainSocketImpl.socketBind(Native Method)
> at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365)
> at java.net.ServerSocket.bind(ServerSocket.java:319)
> at java.net.ServerSocket.<init>(ServerSocket.java:185)
> at
> org.globus.net.ServerSocketFactory.createServerSocket(ServerSocketFactory.java:114)
> at
> org.globus.net.ServerSocketFactory.createServerSocket(ServerSocketFactory.java:68)
> at org.globus.net.BaseServer.<init>(BaseServer.java:84)
> at
> org.globus.cog.karajan.workflow.service.GSSService.<init>(GSSService.java:63)
> at
> org.globus.cog.abstraction.coaster.service.CoasterService.<init>(CoasterService.java:74)
> at
> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.<init>(CoasterPersistentService.java:34)
> at
> org.globus.cog.abstraction.coaster.service.CoasterPersistentService.main(CoasterPersistentService.java:98)
> Perhaps, I need to kill the previously started service but couldn't figure
> how.
> Thanks,
> Ketan
> On Thu, Mar 10, 2011 at 12:01 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
>> It probably means your sites.xml is empty. Can you post it?
>> Mihael
>> On Thu, 2011-03-10 at 09:03 -0600, Ketan Maheshwari wrote:
>> > Submit workflow sleep.swift.
>> > I get error message: No service contacts available.
More information about the Swift-user
