[Swift-user] Errors compiling swift-0.92
Mihael Hategan hategan at mcs.anl.gov
Sat Mar 5 19:54:25 CST 2011
On Sat, 2011-03-05 at 20:25 -0500, Andriy Fedorov wrote:
> On Sat, Mar 5, 2011 at 20:18, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Sat, 2011-03-05 at 20:10 -0500, Andriy Fedorov wrote:
> >> On Sat, Mar 5, 2011 at 20:06, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> >> > Odd. In cog/mbuild.xml, towards the top, there should be a line reading:
> >> > <property name="force.java.version" value="1.5"/>
> >> > Do you have that?
> >> I have <property name="force.java.version" value="1.4"/>
> >> If I change that to 1.5, I still have errors ...
> > Even odder. Can you try a clean checkout?
> Yes, but I just checked it out couple of hours ago fresh! Are there
> any peculiarities with java on linux?
Not that I know of. Linux is the platform on which swift is most used.
But now that I look at the instructions, I think they are wrong. The
correct cog branch is 4.1.8, not 4.1.7.
Mihael
More information about the Swift-user mailing list
