[Swift-user] Errors compiling swift-0.92
Andriy Fedorov fedorov at bwh.harvard.edu
Sat Mar 5 19:25:50 CST 2011
On Sat, Mar 5, 2011 at 20:18, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sat, 2011-03-05 at 20:10 -0500, Andriy Fedorov wrote:
>> On Sat, Mar 5, 2011 at 20:06, Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> > Odd. In cog/mbuild.xml, towards the top, there should be a line reading:
>> > <property name="force.java.version" value="1.5"/>
>> > Do you have that?
>> I have <property name="force.java.version" value="1.4"/>
>> If I change that to 1.5, I still have errors ...
> Even odder. Can you try a clean checkout?
Yes, but I just checked it out couple of hours ago fresh! Are there
any peculiarities with java on linux?
[andrey at beat swift] javac -version
javac 1.6.0_20
[andrey at beat swift] java -version
java version "1.6.0_20"
OpenJDK Runtime Environment (IcedTea6 1.9.7) (6b20-1.9.7-0ubuntu1~10.04.1)
OpenJDK 64-Bit Server VM (build 19.0-b09, mixed mode)
[andrey at beat swift] uname -a
Linux beat 2.6.32-29-generic #58-Ubuntu SMP Fri Feb 11 20:52:10 UTC
2011 x86_64 GNU/Linux
> Mihael
More information about the Swift-user mailing list
