[Swift-user] Errors compiling swift-0.92
Mihael Hategan hategan at mcs.anl.gov
Sat Mar 5 19:06:47 CST 2011
Odd. In cog/mbuild.xml, towards the top, there should be a line reading:
<property name="force.java.version" value="1.5"/>
Do you have that?
On Sat, 2011-03-05 at 18:23 -0500, Andriy Fedorov wrote:
> Hi,
> I have the errors below trying to compile latest release branch on
> Ubuntu 10.04 x86_64 following the instructions on this page:
> http://www.ci.uchicago.edu/swift/downloads/index.php
> Any suggestions?
> delete.dependency.log.1:
>    [delete] Deleting: /home/andrey/local/cog/dependency.log.dist
>      [echo] [swift]: DIST
>      [echo] [swift]: JARCOPY
>      [copy] Copying 9 files to
> /home/andrey/local/cog/modules/swift/dist/swift-svn/lib
>      [copy] Copying 10 files to
> /home/andrey/local/cog/modules/swift/dist/swift-svn/etc
> delete.jar:
>      [echo] [swift]: DELETE.JAR (cog-swift-svn.jar)
> compile:
>      [echo] [swift]: COMPILE
>     [mkdir] Created dir: /home/andrey/local/cog/modules/swift/build
>     [javac] Compiling 374 source files to
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:69:
> generics are not supported in -source 1.4
>     [javac] (use -source 5 or higher to enable generics)
>     [javac]     private List<Profile> profiles;
>     [javac]                 ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:163:
> for-each loops are not supported in -source 1.4
>     [javac] (use -source 5 or higher to enable for-each loops)
>     [javac]             for (Profile p : profiles)
>     [javac]                            ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:394:
> annotations are not supported in -source 1.4
>     [javac] (use -source 5 or higher to enable annotations)
>     [javac]     @SuppressWarnings("hiding")
>     [javac]      ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalog.java:53:
>     [javac]     List<TCEntry> getTCEntries( String namespace, String
> name, String version,
>     [javac]         ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalogEntry.java:71:
>     [javac]                 ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalogEntry.java:165:
>     [javac]                            ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/transformation/File.java:80:
>     [javac]     private Map<String, Map<String, List<TCEntry>>> mTreeMap;
>     [javac]                ^
>     [javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/transformation/File.java:465:
>     [javac]         for (Map<String,List<TCEntry>> lMap : lfnList) {
> [... many more ...]
> Andriy Fedorov, Ph.D.
> Research Fellow
> Brigham and Women's Hospital
> Harvard Medical School
> 75 Francis Street
> Boston, MA 02115 USA
> fedorov at bwh.harvard.edu
> (617) 525-6258 (office)
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user mailing list
