[Swift-user] Errors compiling swift-0.92
Andriy Fedorov
fedorov at bwh.harvard.edu
Sat Mar 5 17:23:12 CST 2011
I have the errors below trying to compile latest release branch on
Ubuntu 10.04 x86_64 following the instructions on this page:
http://www.ci.uchicago.edu/swift/downloads/index.php
Any suggestions?
delete.dependency.log.1:
[delete] Deleting: /home/andrey/local/cog/dependency.log.dist
[echo] [swift]: DIST
[echo] [swift]: JARCOPY
[copy] Copying 9 files to
/home/andrey/local/cog/modules/swift/dist/swift-svn/lib
[copy] Copying 10 files to
/home/andrey/local/cog/modules/swift/dist/swift-svn/etc
delete.jar:
[echo] [swift]: DELETE.JAR (cog-swift-svn.jar)
compile:
[echo] [swift]: COMPILE
[mkdir] Created dir: /home/andrey/local/cog/modules/swift/build
[javac] Compiling 374 source files to
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:69:
generics are not supported in -source 1.4
[javac] (use -source 5 or higher to enable generics)
[javac] private List<Profile> profiles;
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:163:
for-each loops are not supported in -source 1.4
[javac] (use -source 5 or higher to enable for-each loops)
[javac] for (Profile p : profiles)
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TCEntry.java:394:
annotations are not supported in -source 1.4
[javac] (use -source 5 or higher to enable annotations)
[javac] @SuppressWarnings("hiding")
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalog.java:53:
[javac] List<TCEntry> getTCEntries( String namespace, String
name, String version,
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalogEntry.java:71:
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/TransformationCatalogEntry.java:165:
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/transformation/File.java:80:
[javac] private Map<String, Map<String, List<TCEntry>>> mTreeMap;
[javac] ^
[javac] /home/andrey/local/cog/modules/swift/src/org/globus/swift/catalog/transformation/File.java:465:
[javac] for (Map<String,List<TCEntry>> lMap : lfnList) {
[... many more ...]
Andriy Fedorov, Ph.D.
Research Fellow
Brigham and Women's Hospital
Harvard Medical School
75 Francis Street
Boston, MA 02115 USA
(617) 525-6258 (office)
More information about the Swift-user
