[Swift-user] HELP for using Swift~
David Kelly
davidk at ci.uchicago.edu
Fri Dec 23 23:13:18 CST 2011
Ian,
Thank you for the email. I have modified the siteguide to reflect the issues you brought to our attention. The data.txt file has been added to the source repository and will be available in the 0.93 release. Please let us know if you see any other ways in which the documentation can be improved. Thank you!
David
----- Original Message -----
> From: "Dr. Ying Chih Lin" <yclin at cse.nsysu.edu.tw>
> To: swift-user at ci.uchicago.edu
> Sent: Thursday, December 22, 2011 2:32:50 AM
> Subject: [Swift-user] HELP for using Swift~
> Dear Sir or Madam,
> I am a beginner on Swift, and writing to request information about
> running Swift on
> many sites. Here are two problems on the document siteguide.pdf:
> 1). What is the PADS and Fusion in the siteguide.pdf? Could it be
> possible to give
> simple introductions or websites for these terminologies in guide
> documents?
> 2). Section 2.1.4 in the siteguide.pdf says that copying catsn.swift
> and data.txt to
> the current directory, but there is no data.txt in the swift-0.93RC5
> package.
> Thank you very much for your kindness.
> Yours sincerely,
> Ian
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
