[Swift-user] Re: [beagle-users] [SWIFT on Beagle]Cannot Execute Correctly After Submitting Job
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Apr 26 13:43:30 CDT 2011
Hello,
This indicates that the executable is not running on beagle compute nodes. Could you kindly send the commandline and the path to your exe, data etc, and I can try to do some testing using aprun and qsub.
Ketan
On Apr 26, 2011, at 1:26 PM, Weiyang Wang wrote:
> In fact I switched to PrgEnv-gnu to compile it again on Beagle, and it works if I run it plainly on login.beagle
> On Tue, Apr 26, 2011 at 10:53 PM, Ti Leggett <leggett at ci.uchicago.edu> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Was the code you're trying to run compiled on Beagle. IT looks to me like it was compiled on PADS. You must recompile your code on Beagle using the Cray compiler wrappers. Please refer to the Beagle FAQ on how to do this:
> http://www.ci.uchicago.edu/wiki/bin/view/Beagle/DevelopOnBeagle
> On Apr 26, 2011, at 9:34 AM, Weiyang Wang wrote:
> > Hello,
> > I've meet problems when submitting jobs using Swift.
> > My Command Line is like:
> > swift -sites.file ./mysites.xml -tc.file ./tc.data largescale.swift
> > My mysites.xml is like
> > <config>
> > <pool handle="pbs">
> > <execution provider="pbs" url="none" jobManager="local:pbs"/>
> > <profile namespace="globus" key="maxwalltime">0:20:00</profile>
> > <profile namespace="globus" key="workersPerNode">8</profile>
> > <profile namespace="globus" key="ppn">8</profile>
> > <!-- <profile namespace="globus" key="internalHostname">172.5.86.6</profile>-->
> > <profile namespace="globus" key="nodeGranularity">1</profile>
> > <profile namespace="globus" key="maxNodes">5</profile>
> > <profile namespace="karajan" key="jobThrottle">1.99</profile>
> > <profile namespace="karajan" key="initialScore">10000</profile>
> > <profile namespace="globus" key="project">CI-SES000031</profile>
> > <!--gridftp url="local://localhost" />-->
> > <filesystem provider="local"/>
> > <!--scratch>/home/frankwang/tmp</scratch>-->
> > <workdirectory>/gpfs/pads/projects/CI-SES000031/csm/tempswiftwork</workdirectory>
> > </pool>
> > </config>
> > My tc.data is like,
> > pbs echo /bin/echo INSTALLED INTEL32::LINUX null
> > pbs sh /bin/bash INSTALLED INTEL32::LINUX null
> > In my swift script I'm running some gfortran compiled programs(I wrap my fortran programs in sh files), and in my error log file, it shows that
> > /gpfs/pads/projects/CI-SES000031/csm/DSSAT040.EXE: error while loading shared libraries: libgfortran.so.3: cannot open shared object file: No such file or directory
> > I didn't meet the same problem when I run these on PADS, and after I swap the module to PrgEnv-gnu when logging onto Beagle I can also run this DSSAT040.EXE.
> > My guess is, I submit the jobs to a Non-GNU Environment in Beagle.
> > How can I correct this?
> > Thank you.
> > Weiyang
> > _______________________________________________
> > beagle-users mailing list
> > beagle-users at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/beagle-users
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG/MacGPG2 v2.0.14 (Darwin)
> iEYEARECAAYFAk223FkACgkQ4RgdOxQVi0AVxgCeNmnQ0e2xgmIZjQ3vkot1SpWf
> H5MAnjS/VbEaH7vWSJFcSK+2hs1VHo4d
> =8FUi
> -----END PGP SIGNATURE-----
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110426/1547da67/attachment.html>
More information about the Swift-user
