[Swift-user] Re: [beagle-users] [SWIFT on Beagle]Cannot Execute Correctly After Submitting Job
Weiyang Wang
frank.wang04 at gmail.com
Tue Apr 26 14:14:02 CDT 2011
OK, I've "make clean" them and ow I switched to PrgEnv-cray, and going to
use ftn to compile some .for files, although they are currently not
recognizable by ftn. I want them to be compiled as F90 files (maybe I have
to rename them first? )
Could you kindly check out what's going on here within the makefile?
======= the first several lines====
OBJDIR = objCSMINPUT
FC = ftn
FFLAGS = -O 3 -g
INC = -I.
MKDIR = mkdir -p
DIRS = ../Common ../Input
RM = rm -rf
===somewhere it starts compiling===
# Create a list of all source files including folder name
FSRC = $(foreach dir,$(DIRS),$(wildcard $(dir)/*.for))
## Create the list of all object files
TOBJ = $(foreach dir, $(DIRS), $(subst .for,.o,$(notdir $(wildcard
$(dir)/*.for))))
# Create the path to store the object files
FOBJ = $(foreach obj,$(TOBJ),$(OBJDIR)/$(obj))
# Define the subfolders to look for source files
vpath %.for ../Common ../Input
$(OBJDIR)/%.o $(OBJDIR)/%.mod: %.for | $(OBJDIR)
$(FC) $(FFLAGS) $(INC) -o $@ -c $<
../MINPT040.EXE : $(FOBJ)
$(FC) $^ -o $@
On Wed, Apr 27, 2011 at 2:43 AM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> Hello,
> This indicates that the executable is not running on beagle compute nodes.
> Could you kindly send the commandline and the path to your exe, data etc,
> and I can try to do some testing using aprun and qsub.
> Ketan
> On Apr 26, 2011, at 1:26 PM, Weiyang Wang wrote:
> In fact I switched to PrgEnv-gnu to compile it again on Beagle, and it
> works if I run it plainly on login.beagle
> On Tue, Apr 26, 2011 at 10:53 PM, Ti Leggett <leggett at ci.uchicago.edu>wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Was the code you're trying to run compiled on Beagle. IT looks to me like
>> it was compiled on PADS. You must recompile your code on Beagle using the
>> Cray compiler wrappers. Please refer to the Beagle FAQ on how to do this:
>> http://www.ci.uchicago.edu/wiki/bin/view/Beagle/DevelopOnBeagle
>> On Apr 26, 2011, at 9:34 AM, Weiyang Wang wrote:
>> > Hello,
>> > I've meet problems when submitting jobs using Swift.
>> > My Command Line is like:
>> > swift -sites.file ./mysites.xml -tc.file ./tc.data largescale.swift
>> > My mysites.xml is like
>> > <config>
>> > <pool handle="pbs">
>> > <execution provider="pbs" url="none" jobManager="local:pbs"/>
>> > <profile namespace="globus" key="maxwalltime">0:20:00</profile>
>> > <profile namespace="globus" key="workersPerNode">8</profile>
>> > <profile namespace="globus" key="ppn">8</profile>
>> > <!-- <profile namespace="globus"
>> key="internalHostname">172.5.86.6</profile>-->
>> > <profile namespace="globus" key="nodeGranularity">1</profile>
>> > <profile namespace="globus" key="maxNodes">5</profile>
>> > <profile namespace="karajan" key="jobThrottle">1.99</profile>
>> > <profile namespace="karajan" key="initialScore">10000</profile>
>> > <profile namespace="globus" key="project">CI-SES000031</profile>
>> > <!--gridftp url="local://localhost" />-->
>> > <filesystem provider="local"/>
>> > <!--scratch>/home/frankwang/tmp</scratch>-->
>> <workdirectory>/gpfs/pads/projects/CI-SES000031/csm/tempswiftwork</workdirectory>
>> > </pool>
>> > </config>
>> > My tc.data is like,
>> > pbs echo /bin/echo INSTALLED INTEL32::LINUX
>> null
>> > pbs sh /bin/bash INSTALLED INTEL32::LINUX
>> null
>> > In my swift script I'm running some gfortran compiled programs(I wrap my
>> fortran programs in sh files), and in my error log file, it shows that
>> > /gpfs/pads/projects/CI-SES000031/csm/DSSAT040.EXE: error while loading
>> shared libraries: libgfortran.so.3: cannot open shared object file: No such
>> file or directory
>> > I didn't meet the same problem when I run these on PADS, and after I
>> swap the module to PrgEnv-gnu when logging onto Beagle I can also run this
>> DSSAT040.EXE.
>> > My guess is, I submit the jobs to a Non-GNU Environment in Beagle.
>> > How can I correct this?
>> > Thank you.
>> > Weiyang
>> > _______________________________________________
>> > beagle-users mailing list
>> > beagle-users at ci.uchicago.edu
>> > http://mail.ci.uchicago.edu/mailman/listinfo/beagle-users
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG/MacGPG2 v2.0.14 (Darwin)
>> iEYEARECAAYFAk223FkACgkQ4RgdOxQVi0AVxgCeNmnQ0e2xgmIZjQ3vkot1SpWf
>> H5MAnjS/VbEaH7vWSJFcSK+2hs1VHo4d
>> =8FUi
>> -----END PGP SIGNATURE-----
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110427/9d0a3e51/attachment.html>
More information about the Swift-user
