[Swift-user] Re: mapping question
Jonathan Monette
jon.monette at gmail.com
Sun Apr 3 21:28:31 CDT 2011
ok. Thanks.
On Sun, Apr 3, 2011 at 9:27 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sun, 2011-04-03 at 21:18 -0500, Jonathan Monette wrote:
> > Actually in the app call.
> > myapp @infile @outfile @outfile_are @metadata
> Nope. It doesn't have to be. It can very well be empty (i.e. just
> "myapp;") as long as swift is concerned. It will still try to stage in
> all arguments and stage out all returns.
> > On Sun, Apr 3, 2011 at 9:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> > On Sun, 2011-04-03 at 21:05 -0500, Jonathan Monette wrote:
> > > Ok. I thought the if the file was an app return it had to
> > be used so
> > > it will be closed and staged out.
> > Define "used"
> > > On Sun, Apr 3, 2011 at 9:03 PM, Mihael Hategan
> > > wrote:
> > > On Sun, 2011-04-03 at 20:59 -0500, Jonathan Monette
> > wrote:
> > > > Yea but how would I get it back through the app?
> > Would
> > > something
> > > > like
> > > > app ( Image outfile, Image outfile_area )
> > myapp( Image
> > > infile
> > > > Meta metadata)
> > > > myapp @infile @outfile @metadata;
> > > > work? Even though it is not a file used in the
> > app would
> > > the app call
> > > > still map to it? Or do I use the regexp mapper
> > after the
> > > app call?
> > > Swift will try to stage that file out if it's one of
> > the app
> > > returns.
> > > That is irrespective of whether it appears on the
> > command line
> > > or not.
> > > So yes, your example above should work.
> > > Mihael
> > > > On Sun, Apr 3, 2011 at 8:56 PM, Mihael Hategan
> > > > wrote:
> > > > Might the regular expression mapper work?
> > > > Mihael
> > > > On Sun, 2011-04-03 at 19:44 -0500,
> > Jonathan Monette
> > > wrote:
> > > > > Hello,
> > > > > I have a situation that I am not sure
> > how to
> > > resolve. I
> > > > have an
> > > > > app that has this interface.
> > > > > myapp infile outfile metadata
> > > > > The Swift app declaration i have is
> > > > > app ( Image outfile) myapp( Image
> > infile
> > > Meta
> > > > metadata)
> > @metadata;
> > > > > Howerver, myapp creates two files. It
> > creates a
> > > file with
> > > > @outfile as
> > > > > the filename and creates another file
> > that is
> > > @outfile_area
> > > > as the
> > > > > file name. How in swift do I map to the
> > > @outfile_area file
> > > > since it
> > > > > is created just based on the name of
> > outfile?
> > > Currently, I
> > > > don't map
> > > > > the file so the file is not staged out
> > so it is
> > > deleted
> > > > presumably
> > > > > when my jobs have finished executed.
> > This file is
> > > not
> > > > necessary for
> > > > > my workflow to complete but it is
> > another metadata
> > > file that
> > > > helps in
> > > > > the approximation of the final image.
> > > > > On Sun, Apr 3, 2011 at 7:38 PM, Jonathan
> > Monette
> > > > > <jon.monette at gmail.com> wrote:
> > > > > Hello,
> > not sure
> > > how to
> > > > resolve. I
> > > > > have an app that is similar to
> > this.
> > > > > Any intelligent fool can make
> > things
> > > bigger and more
> > > > > complex... It takes a touch of
> > genius -
> > > and a lot of
> > > > courage
> > > > > to move in the opposite
> > direction.
> > > > > - Albert Einstein
> > > > > Any intelligent fool can make things
> > bigger and
> > > more
> > > > complex... It
> > > > > takes a touch of genius - and a lot of
> > courage to
> > > move in
> > > > the opposite
> > > > > direction.
> > > > > - Albert Einstein
> > _______________________________________________
> > > > > Swift-user mailing list
> > > > > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > > > Any intelligent fool can make things bigger and
> > more
> > > complex... It
> > > > takes a touch of genius - and a lot of courage to
> > move in
> > > the opposite
> > > > direction.
> > > > - Albert Einstein
> > > Any intelligent fool can make things bigger and more
> > complex... It
> > > takes a touch of genius - and a lot of courage to move in
> > the opposite
> > > direction.
> > > - Albert Einstein
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110403/2cf2cf42/attachment.html>
More information about the Swift-user
