[Swift-user] Re: mapping question
Mihael Hategan
hategan at mcs.anl.gov
Sun Apr 3 21:27:57 CDT 2011
On Sun, 2011-04-03 at 21:18 -0500, Jonathan Monette wrote:
> Actually in the app call.
> myapp @infile @outfile @outfile_are @metadata
Nope. It doesn't have to be. It can very well be empty (i.e. just
"myapp;") as long as swift is concerned. It will still try to stage in
all arguments and stage out all returns.
> On Sun, Apr 3, 2011 at 9:17 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> On Sun, 2011-04-03 at 21:05 -0500, Jonathan Monette wrote:
> > Ok. I thought the if the file was an app return it had to
> be used so
> > it will be closed and staged out.
> Define "used"
> > On Sun, Apr 3, 2011 at 9:03 PM, Mihael Hategan
> > wrote:
> > On Sun, 2011-04-03 at 20:59 -0500, Jonathan Monette
> wrote:
> > > Yea but how would I get it back through the app?
> Would
> > something
> > > like
> > > app ( Image outfile, Image outfile_area )
> myapp( Image
> > infile
> > > Meta metadata)
> > > myapp @infile @outfile @metadata;
> > > work? Even though it is not a file used in the
> app would
> > the app call
> > > still map to it? Or do I use the regexp mapper
> after the
> > app call?
> > Swift will try to stage that file out if it's one of
> the app
> > returns.
> > That is irrespective of whether it appears on the
> command line
> > or not.
> > So yes, your example above should work.
> > Mihael
> > > On Sun, Apr 3, 2011 at 8:56 PM, Mihael Hategan
> > > wrote:
> > > Might the regular expression mapper work?
> > > Mihael
> > > On Sun, 2011-04-03 at 19:44 -0500,
> Jonathan Monette
> > wrote:
> > > > Hello,
> > > > I have a situation that I am not sure
> how to
> > resolve. I
> > > have an
> > > > app that has this interface.
> > > > myapp infile outfile metadata
> > > > The Swift app declaration i have is
> > > > app ( Image outfile) myapp( Image
> infile
> > Meta
> > > metadata)
> @metadata;
> > > > Howerver, myapp creates two files. It
> creates a
> > file with
> > > @outfile as
> > > > the filename and creates another file
> that is
> > @outfile_area
> > > as the
> > > > file name. How in swift do I map to the
> > @outfile_area file
> > > since it
> > > > is created just based on the name of
> outfile?
> > Currently, I
> > > don't map
> > > > the file so the file is not staged out
> so it is
> > deleted
> > > presumably
> > > > when my jobs have finished executed.
> This file is
> > not
> > > necessary for
> > > > my workflow to complete but it is
> another metadata
> > file that
> > > helps in
> > > > the approximation of the final image.
> > > > On Sun, Apr 3, 2011 at 7:38 PM, Jonathan
> Monette
> > > > <jon.monette at gmail.com> wrote:
> > > > Hello,
> not sure
> > how to
> > > resolve. I
> > > > have an app that is similar to
> this.
> > > > Any intelligent fool can make
> things
> > bigger and more
> > > > complex... It takes a touch of
> genius -
> > and a lot of
> > > courage
> > > > to move in the opposite
> direction.
> > > > - Albert Einstein
> > > > Any intelligent fool can make things
> bigger and
> > more
> > > complex... It
> > > > takes a touch of genius - and a lot of
> courage to
> > move in
> > > the opposite
> > > > direction.
> > > > - Albert Einstein
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > > Any intelligent fool can make things bigger and
> more
> > complex... It
> > > takes a touch of genius - and a lot of courage to
> move in
> > the opposite
> > > direction.
> > > - Albert Einstein
> > Any intelligent fool can make things bigger and more
> complex... It
> > takes a touch of genius - and a lot of courage to move in
> the opposite
> > direction.
> > - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
More information about the Swift-user
