[Swift-user] Re: mapping question
Mihael Hategan
hategan at mcs.anl.gov
Sun Apr 3 21:17:15 CDT 2011
On Sun, 2011-04-03 at 21:05 -0500, Jonathan Monette wrote:
> Ok. I thought the if the file was an app return it had to be used so
> it will be closed and staged out.
Define "used"
> On Sun, Apr 3, 2011 at 9:03 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> On Sun, 2011-04-03 at 20:59 -0500, Jonathan Monette wrote:
> > Yea but how would I get it back through the app? Would
> something
> > like
> > app ( Image outfile, Image outfile_area ) myapp( Image
> infile
> > Meta metadata)
> > myapp @infile @outfile @metadata;
> > work? Even though it is not a file used in the app would
> the app call
> > still map to it? Or do I use the regexp mapper after the
> app call?
> Swift will try to stage that file out if it's one of the app
> returns.
> That is irrespective of whether it appears on the command line
> or not.
> So yes, your example above should work.
> Mihael
> > On Sun, Apr 3, 2011 at 8:56 PM, Mihael Hategan
> > wrote:
> > Might the regular expression mapper work?
> > Mihael
> > On Sun, 2011-04-03 at 19:44 -0500, Jonathan Monette
> wrote:
> > > Hello,
> > > I have a situation that I am not sure how to
> resolve. I
> > have an
> > > app that has this interface.
> > > myapp infile outfile metadata
> > > The Swift app declaration i have is
> > > app ( Image outfile) myapp( Image infile
> Meta
> > metadata)
> > > Howerver, myapp creates two files. It creates a
> file with
> > @outfile as
> > > the filename and creates another file that is
> @outfile_area
> > as the
> > > file name. How in swift do I map to the
> @outfile_area file
> > since it
> > > is created just based on the name of outfile?
> Currently, I
> > don't map
> > > the file so the file is not staged out so it is
> deleted
> > presumably
> > > when my jobs have finished executed. This file is
> not
> > necessary for
> > > my workflow to complete but it is another metadata
> file that
> > helps in
> > > the approximation of the final image.
> > > On Sun, Apr 3, 2011 at 7:38 PM, Jonathan Monette
> > > <jon.monette at gmail.com> wrote:
> > > Hello,
> how to
> > resolve. I
> > > have an app that is similar to this.
> > > Any intelligent fool can make things
> bigger and more
> > > complex... It takes a touch of genius -
> and a lot of
> > courage
> > > to move in the opposite direction.
> > > - Albert Einstein
> > > Any intelligent fool can make things bigger and
> more
> > complex... It
> > > takes a touch of genius - and a lot of courage to
> move in
> > the opposite
> > > direction.
> > > - Albert Einstein
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > Any intelligent fool can make things bigger and more
> complex... It
> > takes a touch of genius - and a lot of courage to move in
> the opposite
> > direction.
> > - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
More information about the Swift-user
