[Swift-user] Re: mapping question
Jonathan Monette jon.monette at gmail.com
Sun Apr 3 21:05:33 CDT 2011
Ok.  I thought the if the file was an app return it had to be used so it
will be closed and staged out.
On Sun, Apr 3, 2011 at 9:03 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Sun, 2011-04-03 at 20:59 -0500, Jonathan Monette wrote:
> > Yea but how would I get it back through the app?  Would something
> > like
> >       app ( Image outfile, Image outfile_area ) myapp( Image infile
> > Meta metadata)
> >            myapp @infile @outfile @metadata;
> > work?  Even though it is not a file used in the app would the app call
> > still map to it?  Or do I use the regexp mapper after the app call?
> Swift will try to stage that file out if it's one of the app returns.
> That is irrespective of whether it appears on the command line or not.
> So yes, your example above should work.
> Mihael
> > On Sun, Apr 3, 2011 at 8:56 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> >         Might the regular expression mapper work?
> >         Mihael
> >         On Sun, 2011-04-03 at 19:44 -0500, Jonathan Monette wrote:
> >         > Hello,
> >         >    I have a situation that I am not sure how to resolve.  I
> >         have an
> >         > app that has this interface.
> >         >       myapp infile outfile metadata
> >         > The Swift app declaration i have is
> >         >       app ( Image outfile) myapp( Image infile Meta
> >         metadata)
> >         > Howerver, myapp creates two files.  It creates a file with
> >         @outfile as
> >         > the filename and creates another file that is @outfile_area
> >         as the
> >         > file name.  How in swift do I map to the @outfile_area file
> >         since it
> >         > is created just based on the name of outfile?  Currently, I
> >         don't map
> >         > the file so the file is not staged out so it is deleted
> >         presumably
> >         > when my jobs have finished executed.  This file is not
> >         necessary for
> >         > my workflow to complete but it is another metadata file that
> >         helps in
> >         > the approximation of the final image.
> >         > On Sun, Apr 3, 2011 at 7:38 PM, Jonathan Monette
> >         > <jon.monette at gmail.com> wrote:
> >         >         Hello,
> >         resolve.  I
> >         >         have an app that is similar to this.
> >         >         Any intelligent fool can make things bigger and more
> >         >         complex... It takes a touch of genius - and a lot of
> >         courage
> >         >         to move in the opposite direction.
> >         >         - Albert Einstein
> >         complex... It
> >         > takes a touch of genius - and a lot of courage to move in
> >         the opposite
> >         > direction.
> >         > - Albert Einstein
> >         > _______________________________________________
> >         > Swift-user mailing list
> >         > Swift-user at ci.uchicago.edu
> >         > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> > Any intelligent fool can make things bigger and more complex... It
> > takes a touch of genius - and a lot of courage to move in the opposite
> > direction.
> > - Albert Einstein
Any intelligent fool can make things bigger and more complex... It takes a
touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20110403/b60b5428/attachment.html>
More information about the Swift-user mailing list
