[Swift-user] persitent service + manual workers
Allan Espinosa
aespinosa at cs.uchicago.edu
Tue Sep 28 17:09:37 CDT 2010
I'm having trouble with the workers registering with the coaster service:
$ ./trunk/bin/coaster-service -nosec
Local contacts: [http://128.135.125.18:50000]
Started local service: http://128.135.125.18:50000
Started coaster service: http://128.135.125.18:1984
SC-null: Disabling heartbeats (config is null)
Multiplexer 0 started
(0) Scheduling SC-null for addition
nullChannel started
Multiplexer 1 started
Unknown handler: REGISTER. Available handlers: {CHMOD=class
org.globus.cog.abstraction.impl.file.coaster.handlers.ChmodHandler,
ISDIR=class org.globus.cog.abstraction.impl.file.coaster.handlers.IsDirectoryHandler,
LIST=class org.globus.cog.abstraction.impl.file.coaster.handlers.ListHandler,
SUBMITJOB=class
org.globus.cog.abstraction.coaster.service.SubmitJobHandler,
MKDIR=class org.globus.cog.abstraction.impl.file.coaster.handlers.MkdirHandler,
PUT=class org.globus.cog.abstraction.impl.file.coaster.handlers.PutFileHandler,
DEL=class org.globus.cog.abstraction.impl.file.coaster.handlers.DeleteHandler,
HEARTBEAT=class
org.globus.cog.karajan.workflow.service.handlers.HeartBeatHandler,
CONFIGSERVICE=class
org.globus.cog.abstraction.coaster.service.ServiceConfigurationHandler,
FILEINFO=class org.globus.cog.abstraction.impl.file.coaster.handlers.FileInfoHandler,
SHUTDOWNSERVICE=class
org.globus.cog.abstraction.coaster.service.ServiceShutdownHandler,
SHUTDOWN=class org.globus.cog.karajan.workflow.service.handlers.ShutdownHandler,
EXISTS=class org.globus.cog.abstraction.impl.file.coaster.handlers.ExistsHandler,
CHANNELCONFIG=class
org.globus.cog.karajan.workflow.service.handlers.ChannelConfigurationHandler,
RMDIR=class org.globus.cog.abstraction.impl.file.coaster.handlers.RmdirHandler,
RENAME=class org.globus.cog.abstraction.impl.file.coaster.handlers.RenameHandler,
VERSION=class org.globus.cog.karajan.workflow.service.handlers.VersionHandler,
WORKERSHELLCMD=class
org.globus.cog.abstraction.coaster.service.WorkerShellHandler,
GET=class org.globus.cog.abstraction.impl.file.coaster.handlers.GetFileHandler}
Worker connection invocation:
$ /home/aespinosa/swift/cogkit/modules/provider-coaster/resources/worker.pl
http://128.135.125.18:1984 foo /home/aespinosa/tmp
Failed to process data: Failed to register (service returned error:
Unknown command: REGISTER) at
line 676.
Invocation through the other port:
http://128.135.125.18:50000 foo /home/aespinosa/tmp
java.lang.NullPointerException) at
line 676.
service dump:
nullChannel started
Received registration: blockid = foo, url =
Avg stream buf: 0
Avg stream buf: 0
Avg stream buf: 0
I'm using the latest trunk code from swift and cog
Just to confirm the "local service" is where swift submits the jobs
and "coaster service" is the one the workers connect to, correct?
-Allan
Allan M. Espinosa <http://amespinosa.wordpress.com>
PhD student, Computer Science
University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
More information about the Swift-user
