[Swift-user] Re: Swift app question
Jonathan Monette
jon.monette at gmail.com
Wed Sep 8 22:32:48 CDT 2010
Here is my actual code I was referencing:
( Image diff_imgs[] ) mDiffBatch( Table diff_tbl, MosaicData hdr )
DiffStruct diffs[] <csv_mapper; file = diff_tbl, skip = 1,
hdelim="| ">;
tracef( "%s is closed %k\n", @filename( hdr ), hdr
); //1
tracef( "Mapped %i files from the csv_mapper and \"%s\"\n",
@length( diffs ), @diff_tbl ); //2
foreach d_entry, i in diffs
tracef( "%s is closed on iteration %i%k\n", @d_entry.plus, i,
d_entry.plus ); //3
tracef( "%s is closed onn iteration %i%k\n", @d_entry.minus,
i, d_entry.minus ); //4
Image proj_1 <single_file_mapper; file = @strcat( "proj_dir/",
@d_entry.plus )>;
Image proj_2 <single_file_mapper; file = @strcat( "proj_dir/",
@d_entry.minus )>;
tracef( "%s is closed on iteration %i%k\n", @proj_1, i, proj_1
); //5
tracef( "%s is closed on iteration %i%k\n", @proj_2, i ,proj_2
); //6
Image diff_img <single_file_mapper; file = @strcat(
"diff_dir/", @d_entry.diff )>;
tracef( "diff_img was mapped to %s on iteration %i\n"
, at diff_img, i ); //7
diff_img = mDiff( proj_1, proj_2, hdr );
tracef( "DIFFERENCED %s on iteration %i%k\n", @filename(
diff_img ), i ,diff_img ); //8
diff_imgs[ i ] = diff_img;
tracef 1 and 2 always print out. tracef 3, 4, 5, 6, and 7 print out
some of the iterations but never all. And the tracef 8 never gets
printed because the script hangs and the app mDiff is never executed.
This is what I have been trying to recreate. But simply taking out the
mDiff app and replacing it with a script that basically does a cat has
the script complete to the end. So I have been trying to understand
what Swift is actually doing.
This code hangs.
On 09/08/2010 10:24 PM, Mihael Hategan wrote:
> On Wed, 2010-09-08 at 21:40 -0500, Jonathan Monette wrote:
>> Ok. And like I said this was a dumbed down example. I just needed to
>> show a mappings and didn't want to use a fancy mapper. In my code x
>> will be a different value for each iteration. Thanks though. That
>> clears things up.
> I was a bit confused. If there is a dependency relation between y and
> the inputs to an app (whether though a mapper or directly) than it has
> to be satisfied for the app to run. However, when it comes to mappers,
> swift allows some hidden dependencies to be expressed. For example when
> some app produces "a.txt" and somewhere you say f<"a.txt">. Swift won't
> enforce that.
> Mihael
More information about the Swift-user
