[Swift-user] Re: Swift app question
Jonathan Monette
jon.monette at gmail.com
Wed Sep 8 21:40:03 CDT 2010
Ok. And like I said this was a dumbed down example. I just needed to
show a mappings and didn't want to use a fancy mapper. In my code x
will be a different value for each iteration. Thanks though. That
clears things up.
On 9/8/10 9:37 PM, Mihael Hategan wrote:
> Theoretically since there is no dependency between m1, m2 and y, it
> should run right ahead. Practically each invocation will probably wait
> for values in years.
> But I have to ask. Why bother doing this for every year if, at least
> from your code, x would have the same value every time (i.e. there is no
> actual dependency on y)?
> Mihael
> On Wed, 2010-09-08 at 21:28 -0500, Jonathan Monette wrote:
>> This is what I meant.
>> foreach y in years
>> Month m1<"month1.txt">;
>> Month m2<"month2.txt">;
>> Year x = calculate( m1, m2 );
>> I know that threads will be created and each iteration for the foreach
>> loop will run in parallel. What I am trying to understand is when is
>> the calculate app executed. This is a very dumbed down example but I
>> want to know will x be mapped to the output of calculate once m1 and m2
>> are closed or is there a "barrier" that blocks until all threads have
>> finished mapping m1 and m2 before the apps are run in parallel?
>> On 9/8/10 9:21 PM, Mihael Hategan wrote:
>>> foreach y in years
>>>> > Month m1< "month1.txt">;
>>>> > Year y = calculate( m1, m2 );
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
