[Swift-user] Re: Status of Swift on Ranger?
Sarah Kenny
skenny at uchicago.edu
Fri Oct 22 12:56:27 CDT 2010
hi glen, we run on ranger using the latest stable branch of swift...users
generate their sites file here:
http://www.ci.uchicago.edu/~skenny/sitesgen/sitegen.php
which will give you pretty good default settings (you'll have to change the
account number and work directory to your own) and then you can tweak it
based on your workflow...as you increase number of cores you request usually
the queue time will increase...
we submit from wherever :) communicado, any of our hnl machines...bridled,
pads logins...feel free to use the hnl install of swift:
/ci/projects/cnari/apps/swift/bin/swift
~sk
On Thu, Oct 21, 2010 at 12:10 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Hi Sarah,
> Glen Hocky would like to start using Ranger for Swift science runs.
> Can you send us a brief update on what you see is the status of Swift on
> Ranger? I.e, what approach works best, and what problems if any to avoid?
> Do you depend on Swift fixes at a specific revision level of trunk?
> Do you submit to Ranger using coasters from a HNL submit host? From
> communicado?
> What sites file and coaster parameters? (I assume these are on the HNL wiki
> - can you send a pointer to Glen?)
> What job-sizing recomendations would you make?
> Have you tried getting coasters to create job-size-spreads on Ranger?
> Thanks,
> Mike
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20101022/b93936fb/attachment.html>
More information about the Swift-user
