[Swift-user] PADS
Mihael Hategan
hategan at mcs.anl.gov
Sun Oct 3 14:17:51 CDT 2010
Ok. I don't think that's related to my commits.
On Sun, 2010-10-03 at 13:44 -0500, Jonathan Monette wrote:
> Here is the compile error:
> generateVersion:
> antlr:
> [java] ANTLR Parser Generator Version 2.7.5 (20050128)
> 1989-2005 jGuru.com
> [java] resources/swiftscript.g:1028: warning:nondeterminism upon
> [java] resources/swiftscript.g:1028: k==1:LBRACK
> k==2:ID,STRING_LITERAL,LBRACK,LPAREN,AT,PLUS,MINUS,STAR,NOT,INT_LITERAL,FLOAT_LITERAL,"true","false"
> [java] resources/swiftscript.g:1028: between alt 1 and exit
> branch of block
> compileSchema:
> [java] IO Error java.io.FileNotFoundException:
> /tmp/xbean5901864127478979310.d/classes/schemaorg_apache_xmlbeans/src/swiftscript.xsd
> (No such file or directory)
> [java] Time to build schema type system: 0.559 seconds
> [java] Exception in thread "main"
> org.apache.xmlbeans.SchemaTypeLoaderException:
> /tmp/xbean5901864127478979310.d/classes/schemaorg_apache_xmlbeans/system/s4846B13C10E24B6C12C8DCBE3348DA75/procedure8537type.xsb
> (schemaorg_apache_xmlbeans.system.s4846B13C10E24B6C12C8DCBE3348DA75.procedure8537type)
> - code 9
> [java] at
> org.apache.xmlbeans.impl.schema.SchemaTypeSystemImpl$XsbReader.getSaverStream(SchemaTypeSystemImpl.java:2214)
> [java] at
> org.apache.xmlbeans.impl.schema.SchemaTypeSystemImpl$XsbReader.writeRealHeader(SchemaTypeSystemImpl.java:1589)
> [java] at
> org.apache.xmlbeans.impl.schema.SchemaTypeSystemImpl.saveType(SchemaTypeSystemImpl.java:1440)
> [java] at
> org.apache.xmlbeans.impl.schema.SchemaTypeSystemImpl.saveTypesRecursively(SchemaTypeSystemImpl.java:1316)
> [java] at
> org.apache.xmlbeans.impl.schema.SchemaTypeSystemImpl.save(SchemaTypeSystemImpl.java:1291)
> [java] at
> org.apache.xmlbeans.impl.tool.SchemaCompiler.compile(SchemaCompiler.java:1098)
> [java] at
> org.apache.xmlbeans.impl.tool.SchemaCompiler.main(SchemaCompiler.java:368)
> BUILD FAILED
> /autonfs/home/jonmon/Library/Swift/trunk/cog/modules/swift/build.xml:247: Java
> returned: 1
> and here is the run error I receive once I compile on a different machine:
> Failed to transfer wrapper log from
> unrectified-20101003-1339-voon0t62/info/l on pads
> Execution failed:
> unrectified-20101003-1339-voon0t62/info/8 on pads
> Exception in mProject:
> Arguments: [-X, raw_dir/2mass-atlas-000713s-j0760245.fits,
> proj_dir/proj_2mass-atlas-000713s-j0760245.fits, header.hdr]
> Host: pads
> Directory: unrectified-20101003-1339-voon0t62/jobs/l/mProject-lvknimzj
> stderr.txt:
> stdout.txt:
> Caused by:
> Task failed:
> org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
> Exitcode file
> (/home/jonmon/.globus/scripts/PBS6388672747278247642.submit.exitcode)
> not found 5 queue polls after the job was reported done
> at
> org.globus.cog.abstraction.impl.scheduler.common.Job.close(Job.java:66)
> at
> org.globus.cog.abstraction.impl.scheduler.common.Job.setState(Job.java:177)
> at
> org.globus.cog.abstraction.impl.scheduler.pbs.QueuePoller.processStdout(QueuePoller.java:126)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.pollQueue(AbstractQueuePoller.java:169)
> at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractQueuePoller.run(AbstractQueuePoller.java:82)
> at java.lang.Thread.run(Thread.java:619)
> The run directory with the files needed to execute and log files is in
> ~jonmon/Workspace/Swift/Montage/katz_slides_test/run.0001
> On 10/3/10 1:30 PM, Mihael Hategan wrote:
> > On Sun, 2010-10-03 at 13:27 -0500, Jonathan Monette wrote:
> >> Hello,
> >> Anyone having a problem using Swift on PADS? I updated Swift and
> >> cog to the most recent from trunk and now I cannot compile Swift on
> >> PADS.
> > I made some recent commits which might be the cause. But I need specific
> > errors.
> > Mihael
> >> I have to use bridled or another ci machine that shares the
> >> filesystem and compile there. I then come back to PADS to execute my
> >> swift script and get all sorts of errors. Is anyone experiencing
> >> similar problems when using PADS?
> Jon
> Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
> - Albert Einstein
More information about the Swift-user
