[Swift-user] runnin' on IBI
Michael Wilde
wilde at mcs.anl.gov
Thu Nov 18 08:31:17 CST 2010
Hi Marc,
Sorry for the delayed response.
I was suspicious that perhaps the (fairly) new SGE provider was not correctly handling error return codes. But I tested it (on ibicluster) with both non-zeroreturn codes and with apps that fail and raise a signal (I tried a divide by by 0 fault).
Everything I tested worked - I was unable to cause the error you received.
Then I tried to run your modftdock swift script - that worked as well (see below). This is in ~wilde/marc if you want to examine how I ran it (see run.sh)
Then I tested with the default Java, which caused first.swift to fail. TO my surprise, that worked as well.
So, the next things to do here are:
- you may want to copy my ~marc directory and see if it works for you
- I would like to get the full logs (and ideally the work directory) from the run(s) that failed for you
- If you could, please try to reproduce the error again and point me to a directory with all your files and and all the files that swift produced.
- also send me your $PATH value so I know what Java you used. (We should log this in the Swift log if its not there already).
Mike
My output was:
[wilde at ibicluster ~]$ pwd
/cchome/wilde
[wilde at ibicluster ~]$ cd marc
[wilde at ibicluster marc]$ ./run.sh
Swift svn swift-r3702 (swift modified locally) cog-r2924 (cog modified locally)
RunID: 20101118-0819-01ot1210
Progress:
SwiftScript trace: 1a25
SwiftScript trace: 1a2z
Progress: Stage in:8
Progress: Submitting:6 Submitted:2
Progress: Submitting:3 Submitted:5
Progress: Submitted:8
Progress: Submitted:7 Active:1
Progress: Active:8
Progress: Active:8
Progress: Active:8
Progress: Active:8
Progress: Active:8
Progress: Active:7 Checking status:1
Progress: Active:4 Stage out:1 Finished successfully:3
Progress: Submitted:1 Active:4 Finished successfully:4
Progress: Active:5 Finished successfully:4
Progress: Active:4 Finished successfully:5
Progress: Active:3 Checking status:1 Finished successfully:5
Progress: Active:3 Finished successfully:6
Progress: Active:2 Checking status:1 Finished successfully:6
Progress: Active:2 Finished successfully:7
Progress: Active:1 Checking status:1 Finished successfully:7
Progress: Submitted:1 Finished successfully:9
Progress: Active:1 Finished successfully:9
Final status: Finished successfully:10
----- Original Message -----
> Hi Mike,
> > Marc, can you point me to the directory in which you performed this
> > run, andmake sure that I can access it?
> there's awful lots of file here... (see below)
> > I am wondering if you changed swift.properties, either by specifying
> > a -config file on the swift command line or by editng
> > swift.properties in your swift build or $HOME/.swift directory?
> I use a "cf" file, and in it I have:
> wrapperlog.always.transfer=true
> sitedir.keep=true
> execution.retries=0
> lazy.errors=false
> status.mode=provider
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> -> I will change the status.mode for "file" tomorrow, and I will let
> you know if it works! If not, then I'll open up my folders and let you
> in :-D
> > As I recall you are using the SGE provider in non-coaster mode,
> > right?
> That's it:
> <config>
> <pool handle="sge">
> <execution provider="sge" url="none"/>
> <filesystem provider="local" url="none"/>
> PS On Swift's website, perhaps you could put the parameter sets that
> "work" or that are "specific" for each site/cluster...? I hope I'm the
> first one using swift on IBI ;-)
> As for my code in SVN, I have no problem with that, but my main
> program has to be compiled 32 bits (I compiled it on godzilla). I
> tried compiling it on a 64 bits machine but the program crashes when
> executing (most likely because of the FFT lib it uses). I would prefer
> transferring the exec instead of an in-place compilation.
> I'll keep you informed,
> Marc.
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
