[Swift-user] Coasters and PBS resource requests: nodes and ppn
Mihael Hategan hategan at mcs.anl.gov
Thu Nov 4 15:41:51 CDT 2010
You can add the ppn profile in sites.xml:
<profile namespace="globus" key="ppn">8</profile>
This works in trunk and might work in the stable branch.
Mihael
On Thu, 2010-11-04 at 10:20 -0500, Michael Wilde wrote:
> Let me see if Mihael or I can add the ppn spec as a simple test to
> experiment with.  I'll look for my coresPerNode mod which I think did
> this.
> - Mike
> ______________________________________________________________________
>         Hi Allan,
>         Yep, that's it. When the coasters resource request comes in
>         with just "nodes=1", it gets interpreted by PBS as
>         nodes=1:ppn=1, and thus PBS puts other jobs on the node, too,
>         until all 8 CPUs are allocated (e.g., 8 1-cpu PBS jobs are
>         running on it).
>         I'd like to find some way to make the request as:
>           nodes=1:ppn=8
>         along with
>           workersPerNode=8
>         so that PBS allocates one node and all 8 processors, and then
>         one Coasters job would put 8 workers on it, matching the
>         resource request with the use.
>         Matthew
>         On Wed, Nov 3, 2010 at 5:41 PM, Allan Espinosa
>         <aespinosa at cs.uchicago.edu> wrote:
>                 Hi Matthew,
>                 Does this mean, coasters will now submit nodes=1;ppn=1
>                 and do node packing?
>                 If there is no node packing being initiated by PBS,
>                 you can just
>                 specify workersPerNode=8 .  But then what you request
>                 to PBS is now
>                 different to what you actually use.
>                 -Allan
>                 2010/11/3 Matthew Woitaszek
>                 <matthew.woitaszek at gmail.com>:
>                 > Good afternoon,
>                 > Is there a way to update PBS resource requests when
>                 using coasters to supply
>                 > modified PBS resource strings such as
>                 "nodes=1:ppn=8"? (Or other arbitrary
>                 > resource requests, such as node properties?)
>                 > Of course, I'm just trying to get coasters to
>                 allocate all of the processors
>                 > on an 8-core node, using either the "gt2:gt2:pbs" or
>                 "local:pbs" provider.
>                 > Both submit jobs just fine. I found no discernible
>                 difference with the
>                 > "host_types" Globus namespace variable, presuming
>                 I'm setting it right.
>                 > The particular cluster I'm using allows node packing
>                 for users that run lots
>                 > of single-processor tasks, so without ppn, it will
>                 assume nodes=1,ncpus=1
>                 > and thus pack 8 jobs on each node before moving on
>                 to the next node. (I know
>                 > it won't be an issue at sites that make nodes
>                 exclusive. On this system, the
>                 > queue default is "nodes=1:ppn=8", but because
>                 coasters explicitly specifies
>                 > the number of nodes in its generated resource
>                 request, the ppn default seems
>                 > to get lost!)
>                 > I see that this has been discussed as far back as
>                 2007, and I found Marcin
>                 > and Mike's previous discussion of the topic at
>                 http://mail.ci.uchicago.edu/pipermail/swift-user/2010-March/001409.html
>                 > but there didn't seem to be any definitive
>                 conclusion. Any suggestions would
>                 > be appreciated!
>                 > Matthew
>                 Allan M. Espinosa <http://amespinosa.wordpress.com>
>                 PhD student, Computer Science
>                 University of Chicago
>                 <http://people.cs.uchicago.edu/~aespinosa>
>         Swift-user mailing list
>         Swift-user at ci.uchicago.edu
>         http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user mailing list
