[Swift-user] Coasters and PBS resource requests: nodes and ppn
Matthew Woitaszek
matthew.woitaszek at gmail.com
Thu Nov 4 10:06:48 CDT 2010
Hi Allan,
Yep, that's it. When the coasters resource request comes in with just
"nodes=1", it gets interpreted by PBS as nodes=1:ppn=1, and thus PBS puts
other jobs on the node, too, until all 8 CPUs are allocated (e.g., 8 1-cpu
PBS jobs are running on it).
I'd like to find some way to make the request as:
nodes=1:ppn=8
along with
workersPerNode=8
so that PBS allocates one node and all 8 processors, and then one Coasters
job would put 8 workers on it, matching the resource request with the use.
Matthew
On Wed, Nov 3, 2010 at 5:41 PM, Allan Espinosa <aespinosa at cs.uchicago.edu>wrote:
> Hi Matthew,
> Does this mean, coasters will now submit nodes=1;ppn=1 and do node packing?
> If there is no node packing being initiated by PBS, you can just
> specify workersPerNode=8 . But then what you request to PBS is now
> different to what you actually use.
> -Allan
> 2010/11/3 Matthew Woitaszek <matthew.woitaszek at gmail.com>:
> > Good afternoon,
> > Is there a way to update PBS resource requests when using coasters to
> supply
> > modified PBS resource strings such as "nodes=1:ppn=8"? (Or other
> arbitrary
> > resource requests, such as node properties?)
> > Of course, I'm just trying to get coasters to allocate all of the
> processors
> > on an 8-core node, using either the "gt2:gt2:pbs" or "local:pbs"
> provider.
> > Both submit jobs just fine. I found no discernible difference with the
> > "host_types" Globus namespace variable, presuming I'm setting it right.
> > The particular cluster I'm using allows node packing for users that run
> lots
> > of single-processor tasks, so without ppn, it will assume nodes=1,ncpus=1
> > and thus pack 8 jobs on each node before moving on to the next node. (I
> know
> > it won't be an issue at sites that make nodes exclusive. On this system,
> the
> > queue default is "nodes=1:ppn=8", but because coasters explicitly
> specifies
> > the number of nodes in its generated resource request, the ppn default
> seems
> > to get lost!)
> > I see that this has been discussed as far back as 2007, and I found
> Marcin
> > and Mike's previous discussion of the topic at
> http://mail.ci.uchicago.edu/pipermail/swift-user/2010-March/001409.html
> > but there didn't seem to be any definitive conclusion. Any suggestions
> would
> > be appreciated!
> > Matthew
> Allan M. Espinosa <http://amespinosa.wordpress.com>
> PhD student, Computer Science
> University of Chicago <http://people.cs.uchicago.edu/~aespinosa<http://people.cs.uchicago.edu/%7Eaespinosa>
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20101104/9e5401ef/attachment.html>
More information about the Swift-user
