[Swift-user] last element array indexing?
Ben Clifford benc at hawaga.org.uk
Mon Mar 22 06:32:12 CDT 2010
If you have map and fold, my beloved functional operators, you get to say
(using haskell-like syntax, because swiftscript has no lambda or
operators-as-functions).
 how many elements in a? = fold (+) (map (\x->1)) a
 whats the last element in a? = fold (\(l,r) -> r) a
 (though that doesn't return an index or anything lvalue like, so you can
  only use this to *read* the last element in a, not write some last
  value)
That first one is quite like the way counting is done in google
map-reduce.
Actual working haskell code:
foldl1 (+) (map (\x->1) [543,213,765])
3
foldl1 (\l->(\r->r)) [1,2,3,4,5]
5
http://www.hawaga.org.uk/ben/
More information about the Swift-user mailing list
