[Swift-user] cannot submit on fusion
Michael Wilde wilde at mcs.anl.gov
Sat Mar 13 11:04:42 CST 2010
Marcin,
I see two problems, the second likely being the result of the first:
In your output file: [ERROR] Parsing profiles on line 21 Illegal character ':'at position 22 :Illegal character ':'
is referring to your tc.data file. I think your Globus MaxWallTime profile entry got moved to a separate line, instead of being separated by tabs as the last column of the previous line.
I suspect that may have caused jobs to get submitted to PBS with defaults that were invalid for the default queue that your jobs are going into, thus causing the second error: Cannot submit job: Could not submit job (qsub reported an exit code of 1). no error output
So fix tc.data, and see if this fixes the problem.
- Mike
----- "Marcin Hitczenko" <marcin at galton.uchicago.edu> wrote:
> Hi Mike,
> Thanks for your response. I am attaching the .log file. Also, the
> swift.out file I included in the original email has the output of my
> run.
> I am including it again.
> Best,
> Marcin
> > Marcin, I forgot to point out: "failed to transfer wrapper log" is
> just a
> > catch-all error message which means "something went wrong with an
> app()
> > job that Swift ran, and the job did not return the expected log file
> that
> > comes from the wrapper script under which Swift runs the job.  We
> need to
> > improve the text of this message.
> > Also, if you can, always run swift with standard output and error
> > redirected into a file, and send that file as well when you report
> a
> > problem.
> > Thanks,
> > Mike
> > ----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> >> Marcin, can you also post the .log file from this run? (it will be
> >> named getcoefs*.log where * is a long unique id including the
> date)
> >> - Mike
> >> > Hi,
> >> > I am trying to run swift scripts on fusion and I am encountering
> an
> >> > error
> >> > I have never had before (The scripts I am running have worked
> >> before).
> >> > It
> >> > seems it is having trouble submitting job because it "failed to
> >> > transfer
> >> > wrapper log". I am including my swift script, tc.data, sites.xml
> >> and
> >> > the
> >> > output file of when I ran it.
> >> > I am not sure if I need to change anything? Like I said, I am
> sure
> >> > the
> >> > same script worked a month or so ago.
> >> > Thanks for your help.
> >> > Best,
> >> > Marcin
> >> > _______________________________________________
> >> > Swift-user mailing list
> >> > Swift-user at ci.uchicago.edu
> >> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> >> Michael Wilde
> >> Computation Institute, University of Chicago
> >> Mathematics and Computer Science Division
> >> Argonne National Laboratory
> > Michael Wilde
Michael Wilde
More information about the Swift-user mailing list
