[Swift-user] cannot submit on fusion
Michael Wilde
wilde at mcs.anl.gov
Sat Mar 13 10:36:01 CST 2010
Marcin, I forgot to point out: "failed to transfer wrapper log" is just a catch-all error message which means "something went wrong with an app() job that Swift ran, and the job did not return the expected log file that comes from the wrapper script under which Swift runs the job. We need to improve the text of this message.
Also, if you can, always run swift with standard output and error redirected into a file, and send that file as well when you report a problem.
Mike
----- "Michael Wilde" <wilde at mcs.anl.gov> wrote:
> Marcin, can you also post the .log file from this run? (it will be
> named getcoefs*.log where * is a long unique id including the date)
> - Mike
> ----- "Marcin Hitczenko" <marcin at galton.uchicago.edu> wrote:
> > Hi,
> > I am trying to run swift scripts on fusion and I am encountering an
> > error
> > I have never had before (The scripts I am running have worked
> before).
> > It
> > seems it is having trouble submitting job because it "failed to
> > transfer
> > wrapper log". I am including my swift script, tc.data, sites.xml
> and
> > the
> > output file of when I ran it.
> > I am not sure if I need to change anything? Like I said, I am sure
> > the
> > same script worked a month or so ago.
> > Thanks for your help.
> > Best,
> > Marcin
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Michael Wilde
More information about the Swift-user
