[Swift-user] cannot submit on fusion
Marcin Hitczenko marcin at galton.uchicago.edu
Sat Mar 13 10:04:07 CST 2010
I am trying to run swift scripts on fusion and I am encountering an error
I have never had before (The scripts I am running have worked before). It
seems it is having trouble submitting job because it "failed to transfer
wrapper log". I am including my swift script, tc.data, sites.xml and the
output file of when I ran it.
I am not sure if I need to change anything? Like I said, I am sure the
same script worked a month or so ago.
Thanks for your help.
Best,
Marcin
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100313/4e5c36a3/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100313/4e5c36a3/attachment-0001.obj>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100313/4e5c36a3/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100313/4e5c36a3/attachment-0002.obj>
More information about the Swift-user mailing list
