[Swift-user] Running swift with the sge provider
Mihael Hategan
hategan at mcs.anl.gov
Fri Mar 12 16:35:11 CST 2010
They aren't only different compilers. GCJ also provides its own
re-implementation of the java core libraries. Unfortunately GCJ doesn't
quite work.
I suspect the sun JDK is already installed on the cluster. Try playing
with softenv or ask an admin.
On Fri, 2010-03-12 at 16:20 -0600, Mark Maienschein-Cline wrote:
> I sort of see... these are different compilers? Does this mean we will have to change the java compiler on the cluster?
> Thanks,
> Mark
> On Mar 12, 2010, at 4:09 PM, Mihael Hategan wrote:
> > Ooops. Right. The GCJ conspiracy is getting more subtle.
> > Try a proper JVM/JDK. You seem to be using GCJ which, well, is at least
> > trying very hard.
> > On Fri, 2010-03-12 at 16:02 -0600, Mark Maienschein-Cline wrote:
> >> Got the same error with that change.
> >> On Mar 12, 2010, at 3:59 PM, Mihael Hategan wrote:
> >>> I'd try url="localhost" instead of url="none" in sge.xml
> >>> On Fri, 2010-03-12 at 15:53 -0600, Mark Maienschein-Cline wrote:
> >>>> Caused by:
> >>>> Could not submit job
> >>>> Caused by:
> >>>> Could not start coaster service
> >>>> Caused by:
> >>>> java.lang.IllegalArgumentException: Address type not supported
> >>>> Cleaning up...
> >>>> Done
More information about the Swift-user
