[Swift-user] Running swift with the sge provider
Mark Maienschein-Cline
mmaiensc at uchicago.edu
Fri Mar 12 15:53:17 CST 2010
I've tried running swift with the sge provider, and I get the following error:
Swift svn swift-r3255 (swift modified locally) cog-r2723 (cog modified locally)
RunID: 20100312-1646-8zx0vx6f
Progress:
Progress: Submitted:1
Failed to transfer wrapper log from pipeline2-20100312-1646-8zx0vx6f/info/r on sge
Execution failed:
Exception in comppeaks:
Arguments: [export3/chip-seq/analyses/mmc_analyses/mmc-irf4-D3-2_q1.1pct.xls export3/chip-seq/analyses/mmc_analyses/mmc-irf4-D3-3_q1.1pct.xls, 200, export3/chip-seq/analyses/mmc_analyses/mmc-irf4-D3-overlap.xls]
Host: sge
Directory: pipeline2-20100312-1646-8zx0vx6f/jobs/r/comppeaks-rkd2i0pj
stderr.txt:
stdout.txt:
Caused by:
Could not submit job
Caused by:
Could not start coaster service
Caused by:
java.lang.IllegalArgumentException: Address type not supported
Cleaning up...
Done
I'm running a stable version of swift, download from PADS on March 3. I've attached the swift script, tc file, and sites file I used, and the log file. Is there something else my cluster needs to run swift on the nodes (my cluster is sisboombah.uchicago.edu)? This script does work locally.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100312/1adb76f2/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100312/1adb76f2/attachment-0001.obj>
Type: application/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100312/1adb76f2/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100312/1adb76f2/attachment-0002.obj>
More information about the Swift-user
