[Swift-user] Re: Runtime error
Jonathan Monette
jon.monette at gmail.com
Wed Jun 23 16:57:12 CDT 2010
Yes. I believe the problem has been solved. Thanks.
On 6/23/10 4:22 PM, Mihael Hategan wrote:
> Try file = diff_tbl.
> If you say @diff_tbl, that is the file name and it is known before the
> file is generated, which means the csv mapper does not see any reason to
> wait.
> Mihael
> On Wed, 2010-06-23 at 14:00 -0500, Jonathan Monette wrote:
>> Hello,
>> I am getting a runtime exception for no such file of directory. Here is
>> the exact error:
>> Swift svn swift-r3343 cog-r2757
>> RunID: 20100623-1340-76qi2b0c
>> Progress:
>> Execution failed:
>> java.lang.RuntimeException: diffs.tbl (No such file or directory)
>> There are several function calls before the one that fails but it seems
>> that none of the other calls run. The diffs.tbl file is suppose to be
>> created in one of these function calls that isn't running. The line I
>> believe that is causing the problems is:
>> DiffStruct diffs[]<csv_mapper; file = @diff_tbl, skip = 1, hdelim = "| ">;
>> If I comment out the function call that contains this line the script
>> runs perfectly. But as soon as I un-comment this line it fails with the
>> runtime exception above. Is the csv_mapper always the first thing to
>> run no matter what or is there some implementation detail I have
>> overlooked. Any thoughts?
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
