[Swift-user] Re: Runtime error
Mihael Hategan
hategan at mcs.anl.gov
Wed Jun 23 16:22:39 CDT 2010
Try file = diff_tbl.
If you say @diff_tbl, that is the file name and it is known before the
file is generated, which means the csv mapper does not see any reason to
wait.
Mihael
On Wed, 2010-06-23 at 14:00 -0500, Jonathan Monette wrote:
> Hello,
> I am getting a runtime exception for no such file of directory. Here is
> the exact error:
> Swift svn swift-r3343 cog-r2757
> RunID: 20100623-1340-76qi2b0c
> Progress:
> Execution failed:
> java.lang.RuntimeException: diffs.tbl (No such file or directory)
> There are several function calls before the one that fails but it seems
> that none of the other calls run. The diffs.tbl file is suppose to be
> created in one of these function calls that isn't running. The line I
> believe that is causing the problems is:
> DiffStruct diffs[] <csv_mapper; file = @diff_tbl, skip = 1, hdelim = "| ">;
> If I comment out the function call that contains this line the script
> runs perfectly. But as soon as I un-comment this line it fails with the
> runtime exception above. Is the csv_mapper always the first thing to
> run no matter what or is there some implementation detail I have
> overlooked. Any thoughts?
More information about the Swift-user
