[Swift-user] Directory mappers
Michael Wilde
wilde at mcs.anl.gov
Sat Feb 27 13:02:06 CST 2010
Right, I agree, ext_mapper is what you want here, Mark. Documented in the user guide at:
http://www.ci.uchicago.edu/swift/guides/userguide.php#mapper.ext_mapper
You can pass parameters such as the location of the higher parent directory.
When using an ext mapper as an output mapper for an array, you need (at the moment) to know in advance how many members you are expecting. We're discussing ways to remove that limitation.
- Mike
----- "Allan Espinosa" <aespinosa at cs.uchicago.edu> wrote:
> Hi Mark,
> For most of my complex input output data specifications, I always use
> the
> ext_mapper since I can always make a script to specify what kind of
> data i want.
> a typical example script would be
> #!/bin/bash
> n=35
> for i in `seq 0 $n`; do
> [$i] expt$i/data.txt
> done
> -Allan
> On Fri, Feb 26, 2010 at 02:31:30PM -0600, Mark Maienschein-Cline
> wrote:
> > Hi,
> > I have a large number of data directories, each with a specific file
> I would
> > need to run analysis on. For example, I have directories expt1/,
> expt2/,
> > expt3/, ..., and the files I need to map are in
> "expt1/output/data.txt" (and
> > the same for the other experiments). The file name is always the
> same, but the
> > directory changes. Is there a mapper that can get all of the
> "data.txt" files
> > for me?
> > Thanks,
> > Mark_______________________________________________
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
