[Swift-user] Re: How to set provider-specific options?
Mihael Hategan hategan at mcs.anl.gov
Thu Feb 25 15:06:14 CST 2010
No. But you missed:
 script = File.createTempFile(getName(), ".submit", scriptdir);
 script.deleteOnExit();
On Thu, 2010-02-25 at 14:58 -0600, Michael Wilde wrote:
> Did I mis-interpret the following code in AbstractExecutor.java?
>         protected void cleanup() {
>                 if (!getProperties().isDebugEnabled()) {
>                         script.delete();
>                         new File(exitcode).delete();
>                         if (spec.getStdOutput() == null && stdout != null) {
>                                 new File(stdout).delete();
>                         if (spec.getStdError() == null && stderr != null) {
>                                 new File(stderr).delete();
> - Mike
> ----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> > On Thu, 2010-02-25 at 14:46 -0600, wilde at mcs.anl.gov wrote:
> > > I tried to set debug=true as the last line in
> > > etc/provider-pbs.properties in my swift dist directory, hoping to
> > get
> > > the PBS provider to retain the .submit file in ~/.globus/scripts.
> > > That didnt seem to work: I didnt get a .submit file there.
> > I don't see any code that would prevent the deletion of the script if
> > debug was set to true in that file.
> > What I would suggest is submitting some long-ish job and then copying
> > the submit scripts from ~/.globus/scripts before they go away.
More information about the Swift-user mailing list
