[Swift-user] Re: How to set provider-specific options?
Michael Wilde wilde at mcs.anl.gov
Thu Feb 25 14:58:36 CST 2010
Did I mis-interpret the following code in AbstractExecutor.java?
        protected void cleanup() {
                if (!getProperties().isDebugEnabled()) {
                        script.delete();
                        new File(exitcode).delete();
                        if (spec.getStdOutput() == null && stdout != null) {
                                new File(stdout).delete();
                        if (spec.getStdError() == null && stderr != null) {
                                new File(stderr).delete();
- Mike
----- "Mihael Hategan" <hategan at mcs.anl.gov> wrote:
> On Thu, 2010-02-25 at 14:46 -0600, wilde at mcs.anl.gov wrote:
> > I tried to set debug=true as the last line in
> > etc/provider-pbs.properties in my swift dist directory, hoping to
> get
> > the PBS provider to retain the .submit file in ~/.globus/scripts.
> > That didnt seem to work: I didnt get a .submit file there.
> I don't see any code that would prevent the deletion of the script if
> debug was set to true in that file.
> What I would suggest is submitting some long-ish job and then copying
> the submit scripts from ~/.globus/scripts before they go away.
More information about the Swift-user mailing list
