[Swift-user] Re: [Swift-devel] Problem with iterate
Ioan Raicu iraicu at cs.uchicago.edu
Fri Feb 19 11:01:55 CST 2010
Sent again from my UChicago adress:
Ioan Raicu wrote:
> But lets bring this back to a more real example. A user wanting to
> express some computations that have some dependencies, would write out
> their computations in some order, expecting their order to be
> preserved because of the dependencies. If you only support single
> assignment on variables (e.g. the data), then an example like the one
> below could never deadlock because the single assignment would be
> violated on the 2nd statement. Perhaps things are more complicated if
> you support multiple assignments per variables, but that is not the
> case for Swift, right?
> I am trying to understand if this deadlock is happening in Swift due
> to some particular implementation detail in Swift (or underlying
> pieces), or is it a fundamental flaw in the DAG based approach with
> single assignment variables? Or is it due to something completely
> different?
> Thanks,
> Ioan
> Ioan Raicu, Ph.D.
> NSF/CRA Computing Innovation Fellow
> Center for Ultra-scale Computing and Information Security (CUCIS)
> Department of Electrical Engineering and Computer Science
> Northwestern University
> 2145 Sheridan Rd, Tech M384
> Evanston, IL 60208-3118
> Cel:   1-847-722-0876
> Tel:   1-847-491-8163
> Email: iraicu at eecs.northwestern.edu
> Web:   http://www.eecs.northwestern.edu/~iraicu/
>        https://wiki.cucis.eecs.northwestern.edu/
> Ben Clifford wrote:
>>> Mathematically, the two different sequences evaluate to different values:
>>> x = y + 1
>>> y = x + 1
>>> assuming y = 0, x = 1
>> I mean in simultaneous equations (linear algebra) - in other words, "find
>> (through whatever means you care to use) a value of x and y such that the
>> above two equations are both satisfied" - there is no value of x and y
>> that satisfies that.
Ioan Raicu, Ph.D.
Cel:   1-847-722-0876
Tel:   1-847-491-8163
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20100219/b043de14/attachment.html>
More information about the Swift-user mailing list
