[Swift-user] Re: [Swift-devel] Problem with iterate
Mihael Hategan
hategan at mcs.anl.gov
Thu Feb 18 11:04:49 CST 2010
On Thu, 2010-02-18 at 08:46 +0000, Ben Clifford wrote:
> > Why was that flag
> > set to "not partial writer"?
> I think that was a bug rather than some deep reason.
> > How did iterate ever work? What am I missing?
> I think it may have only ever worked in the initialise-in-nested-if case
> (or fairly trivial test cases which don't run into this problem)
> > Ideas?
> I'm split between two minds:
> a) more static and runtime analysis can lead to some (informally
> provable?) correct behaviour here. It think it might be possible to at
> least detect deadlocks caused by this and more elegantly error out, by
> finding cycles in a graph of who is waiting for what, which is a
> better user experience than a deadlock (as in, you can type the
> deadlock message into google and get the beautiful documentation page
> all about resolving such problems)
> b) that having multiple writer arrays and foreach/iterate control
> structures in their present for are (informally provably?) inherently
> deadlock prone and no matter what is done, it will always be possible
> to contrive a deadlock; and so then to have a "correct" system, those
> structures need to fundamentally change.
I'm unsure. I have a feeling that static dealdock detection is
undecidable in swift. I need to think some more about that.
> Even if b is the case, it might be that problems are sufficiently obscure
> that it doesn't matter from the "lets run a bazillion protein folds"
> perspective.
Right. Which is what we've been doing so far.
More information about the Swift-user
