provider staging to remote sites (was [Swift-user] Re: 3rd party transfers)
Michael Wilde wilde at mcs.anl.gov
Fri Dec 10 11:20:38 CST 2010
Hi Allan,
I vaguely recall similar issues with prior tests of provider staging. Based on Mihael's recommendation Ive been using the "proxy" mode. I dont have my head around all the modes at the moment (I did when I first looked at it).
At any rate, in my tests using proxy mode, just on localhost, I did not run into any full-pathname problems: I used simple_mapper and unqualified partial pathnames.
My test is on the CI net at: /home/wilde/swift/lab/tests/test.local.ps.sh
and pasted below.  We should build a similar test to validate proxy-mode provider staging on remote sites with coasters.  Whoever gets to it first.
See if using the pattern below gets you past this full-pathname problem.
- Mike
bri$ cat ./test.local.ps.sh
#! /bin/bash
cat >tc <<END
localhost sh /bin/sh null null null
localhost cat /bin/cat null null null
END
cat >sites.xml <<END
<config>
  <pool handle="localhost">
    <execution provider="coaster" url="none" jobmanager="local:local"/>
    <profile namespace="globus" key="workersPerNode">8</profile>
    <profile namespace="globus" key="slots">1</profile>
    <profile namespace="globus" key="maxnodes">1</profile>
    <profile key="jobThrottle" namespace="karajan">.15</profile>
    <profile namespace="karajan" key="initialScore">10000</profile>
    <profile namespace="swift" key="stagingMethod">proxy</profile>
    <workdirectory>$PWD</workdirectory>
  </pool>
</config>
END
cat >cf <<END
wrapperlog.always.transfer=true
sitedir.keep=true
execution.retries=0
lazy.errors=false
status.mode=provider
use.provider.staging=true
provider.staging.pin.swiftfiles=false
END
cat >pstest.swift <<EOF
type file;
app (file o) cat (file i)
  cat @i stdout=@o;
file infile[]  <simple_mapper; location="indir", prefix="f.", suffix=".in">;
file outfile[] <simple_mapper; location="outdir", prefix="f.",suffix=".out">;
foreach f, i in infile {
  outfile[i] = cat(f);
EOF
swift -config cf -tc.file tc -sites.file sites.xml pstest.swift
bri$
bri$ mkdir outdir
bri$ ls
indir/  outdir/  test.local.ps.sh
bri$ ls indir
f.0000.in  f.0001.in  f.0002.in  f.0003.in  f.0004.in
bri$ ls outdir
bri$ ./test.local.ps.sh
Swift svn swift-r3758 cog-r2951 (cog modified locally)
RunID: 20101210-1108-qsdi3mz6
Progress:
Progress:  Active:4  Finished successfully:1
Final status:  Finished successfully:5
bri$ ls outdir
f.0000.out  f.0001.out  f.0002.out  f.0003.out  f.0004.out
bri$
----- Original Message -----
> Hi Mike,
> I'm having problems getting provider staging to work. I seems to pass
> files as absolute references:
> _____________________________________________________________________________
> command line
> -e /bin/cat -out stdout.txt -err stderr.txt -i -d -if
> //gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations/100/0/100_0.txt.variation-s0000-h0000
> -of -k -cdmfile -status provider -a
> stdout
> stderr
> /bin/cat:
> /gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations/100/0/100_0.txt.variation-s0000-h0000:
> No such file or directory
> But the remote site does not have /gpfs/pads .
> Should I be modifying my mappers to accomodate this?
> -Allan
> 2010/12/10 Michael Wilde <wilde at mcs.anl.gov>:
> > Did you try provider staging, which might be easier to throttle
> > given that the staging endpoints are more under Swift's control?
> > - MIke
> >> Hi Mike.
> >> Yes. I had the workflow stagein 1, 10, 40 , 80, 400, 800, 2000,
> >> 8000,
> >> 30000 files. The throttles are the same for each run. Problems
> >> started to occur at around 800 files .
> >> For staging in local files, problems started to occur at 30000
> >> files
> >> where vdl:dostagein hits gpfs too much.
> >> -Allan
> >> > Allan, did you verify that each remote site you are talking to in
> >> > this test is functional at low transaction rates using your
> >> > current
> >> > sites configuration?
> >> > I.e., are you certain that the error below is due to load and not
> >> > a
> >> > site-related error?
> >> > - Mike
> >> >> I tried to have the tests more synthesized using Mike's catsall
> >> >> workflow staging in ~3 MB data files to 5 OSG sites. Swift seem
> >> >> to
> >> >> handle the transfer well when the originating files are local.
> >> >> But
> >> >> when it starts to use remote file objects, I get all these 3rd
> >> >> party
> >> >> transfer exceptions. my throttle for file transfers is 8 and for
> >> >> file
> >> >> operations is 10.
> >> >> 2010-12-09 18:58:16,700-0600 DEBUG DelegatedFileTransferHandler
> >> >> File
> >> >> transfer with resource remote->tmp
> >> >> 2010-12-09 18:58:16,734-0600 DEBUG DelegatedFileTransferHandler
> >> >> Exception in transfer
> >> >> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
> >> >> Exception in getFile
> >> >> at
> >> >> org.globus.cog.abstraction.impl.file.ftp.AbstractFTPFileResource.translateException(AbstractFTP
> >> >> FileResource.java:62)
> >> >> at
> >> >> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.getFile(FileResourceImpl.java
> >> >> :401)
> >> >> at
> >> >> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doSource(DelegatedFil
> >> >> eTransferHandler.java:269)
> >> >> at
> >> >> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doSource(Cachi
> >> >> ngDelegatedFileTransferHandler.java:59)
> >> >> at
> >> >> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTran
> >> >> sferHandler.java:486)
> >> >> at java.lang.Thread.run(Thread.java:619)
> >> >> Caused by:
> >> >> org.globus.cog.abstraction.impl.file.FileResourceException:
> >> >> Failed to retrieve file information
> >> >> about
> >> >> /projsmall/osg/data/engage/scec/swift_scratch/catsall-20101209-1839-pnazhid6/info/p/cat-p2em5s2k-in
> >> >> fo
> >> >> at
> >> >> FileResource.java:51)
> >> >> at
> >> >> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.getGridFile(FileResourceImpl.
> >> >> java:550)
> >> >> at
> >> >> :384)
> >> >> ... 4 more
> >> >> Caused by: org.globus.ftp.exception.ServerException: Server
> >> >> refused
> >> >> performing the request. Custom message
> >> >> : Server refused MLST command (error code 1) [Nested exception
> >> >> message: Custom message: Unexpected reply:
> >> >> 500-Command failed :
> >> >> globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
> >> >> 500-System error in stat: No such file or directory
> >> >> 500-A system call failed: No such file or directory
> >> >> 500 End.] [Nested exception is
> >> >> org.globus.ftp.exception.UnexpectedReplyCodeException: Custom
> >> >> message: Une
> >> >> xpected reply: 500-Command failed :
> >> >> 500 End.]
> >> >> at
> >> >> org.globus.ftp.exception.ServerException.embedUnexpectedReplyCodeException(ServerException.java
> >> >> :101)
> >> >> at org.globus.ftp.FTPClient.mlst(FTPClient.java:643)
> >> >> at
> >> >> java:546)
> >> >> ... 5 more
> >> >> I may have been stressing the source gridftp server too much
> >> >> (pads)
> >> >> that it cannot handle a throttle of 8 . But at this
> >> >> configuration,
> >> >> I
> >> >> get low transfer performance. When doing direct transfers, I was
> >> >> able
> >> >> to get better transfer rates until i start coking out gpfs at
> >> >> 10k
> >> >> stageins. My throttle for this configurations was 40 for both
> >> >> file
> >> >> transfers and file operations.
> >> >> 2010/12/2 Allan Espinosa <aespinosa at cs.uchicago.edu>:
> >> >> > I have a bunch of 3rd party gridftp transfers. Swift reports
> >> >> > around
> >> >> > 10k jobs being in the vdl:stagein at a time. After a while i
> >> >> > get
> >> >> > a
> >> >> > couple of these errors. Does it look like i'm stressing the
> >> >> > gridftp
> >> >> > servers? my throttle.transfers=8
> >> >> > 2010-12-02 02:22:06,008-0600 DEBUG
> >> >> > Starting service on gsiftp://gpn-hus
> >> >> > File
> >> >> > transfer with resource local->r
> >> >> > 2010-12-02 02:22:06,247-0600 DEBUG
> >> >> >        at
> >> >> > esource.java:51)
> >> >> >        at
> >> >> > esource.java:34)
> >> >> >        at
> >> >> >        org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImp
> >> >> >        at
> >> >> >        org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(D
> >> >> > eTransferHandler.java:352)
> >> >> >        at
> >> >> >        org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestin
> >> >> > ngDelegatedFileTransferHandler.java:46)
> >> >> >        at
> >> >> > andler.java:489)
> >> >> > refused
> >> >> > rror code 1) [Nested exception message: Custom message:
> >> >> > Unexpected
> >> >> > reply: 451 ocurred during retrie
> >> >> > org.globus.ftp.exception.DataChannelException: setPassive()
> >> >> > must
> >> >> > match
> >> >> > store() and setActive() - ret
> >> >> > rror code 2)
> >> >> > must
> >> >> > match
> >> >> > rror code 2)
> >> >> >        at
> >> >> >        org.globus.ftp.extended.GridFTPServerFacade.retrieve(GridFTPServerFacade.java:469)
> >> >> >        at org.globus.ftp.FTPClient.put(FTPClient.java:1294)
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> > andler.java:489)
> >> >> > message: Unexp
> >> >> > : 451 ocurred during retrieve()
> >> >> > must
> >> >> > match
> >> >> > rror code 2)
> >> >> > must
> >> >> > match
> >> >> > rror code 2)
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> > andler.java:489)
> >> >> >        at
> >> >> >        at
> >> >> >        at
> >> >> >        org.globus.ftp.vanilla.TransferMonitor.run(TransferMonitor.java:195)
> >> >> >        ... 1 more
> >> Allan M. Espinosa <http://amespinosa.wordpress.com>
> >> PhD student, Computer Science
> >> University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
Michael Wilde
More information about the Swift-user mailing list
