provider staging to remote sites (was [Swift-user] Re: 3rd party transfers)
Allan Espinosa aespinosa at cs.uchicago.edu
Fri Dec 10 10:44:10 CST 2010
Hi Mike,
I'm having problems getting provider staging to work.  I seems to pass
files as absolute references:
_____________________________________________________________________________
        command line
-e /bin/cat -out stdout.txt -err stderr.txt -i -d -if
//gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations/100/0/100_0.txt.variation-s0000-h0000
-of -k -cdmfile -status provider -a
        stdout
        stderr
/bin/cat: /gpfs/pads/swift/aespinosa/science/cybershake/RuptureVariations/100/0/100_0.txt.variation-s0000-h0000:
No such file or directory
But the remote site does not have /gpfs/pads .
Should I be modifying my mappers to accomodate this?
-Allan
2010/12/10 Michael Wilde <wilde at mcs.anl.gov>:
> Did you try provider staging, which might be easier to throttle given that the staging endpoints are more under Swift's control?
> - MIke
>> Hi Mike.
>> Yes. I had the workflow stagein 1, 10, 40 , 80, 400, 800, 2000, 8000,
>> 30000 files. The throttles are the same for each run. Problems
>> started to occur at around 800 files .
>> For staging in local files, problems started to occur at 30000 files
>> where vdl:dostagein hits gpfs too much.
>> -Allan
>> > Allan, did you verify that each remote site you are talking to in
>> > this test is functional at low transaction rates using your current
>> > sites configuration?
>> > I.e., are you certain that the error below is due to load and not a
>> > site-related error?
>> > - Mike
>> >> I tried to have the tests more synthesized using Mike's catsall
>> >> workflow staging in ~3 MB data files to 5 OSG sites. Swift seem to
>> >> handle the transfer well when the originating files are local. But
>> >> when it starts to use remote file objects, I get all these 3rd
>> >> party
>> >> transfer exceptions. my throttle for file transfers is 8 and for
>> >> file
>> >> operations is 10.
>> >> 2010-12-09 18:58:16,700-0600 DEBUG DelegatedFileTransferHandler
>> >> File
>> >> transfer with resource remote->tmp
>> >> 2010-12-09 18:58:16,734-0600 DEBUG DelegatedFileTransferHandler
>> >> Exception in transfer
>> >> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
>> >> Exception in getFile
>> >> at
>> >> org.globus.cog.abstraction.impl.file.ftp.AbstractFTPFileResource.translateException(AbstractFTP
>> >> FileResource.java:62)
>> >> at
>> >> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.getFile(FileResourceImpl.java
>> >> :401)
>> >> at
>> >> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doSource(DelegatedFil
>> >> eTransferHandler.java:269)
>> >> at
>> >> org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doSource(Cachi
>> >> ngDelegatedFileTransferHandler.java:59)
>> >> at
>> >> org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTran
>> >> sferHandler.java:486)
>> >> at java.lang.Thread.run(Thread.java:619)
>> >> Caused by:
>> >> org.globus.cog.abstraction.impl.file.FileResourceException:
>> >> Failed to retrieve file information
>> >> about
>> >> /projsmall/osg/data/engage/scec/swift_scratch/catsall-20101209-1839-pnazhid6/info/p/cat-p2em5s2k-in
>> >> fo
>> >> at
>> >> FileResource.java:51)
>> >> at
>> >> org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.getGridFile(FileResourceImpl.
>> >> java:550)
>> >> at
>> >> :384)
>> >> ... 4 more
>> >> Caused by: org.globus.ftp.exception.ServerException: Server refused
>> >> performing the request. Custom message
>> >> : Server refused MLST command (error code 1) [Nested exception
>> >> message: Custom message: Unexpected reply:
>> >> 500-Command failed :
>> >> globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
>> >> 500-System error in stat: No such file or directory
>> >> 500-A system call failed: No such file or directory
>> >> 500 End.] [Nested exception is
>> >> org.globus.ftp.exception.UnexpectedReplyCodeException: Custom
>> >> message: Une
>> >> xpected reply: 500-Command failed :
>> >> 500 End.]
>> >> at
>> >> org.globus.ftp.exception.ServerException.embedUnexpectedReplyCodeException(ServerException.java
>> >> :101)
>> >> at org.globus.ftp.FTPClient.mlst(FTPClient.java:643)
>> >> at
>> >> java:546)
>> >> ... 5 more
>> >> I may have been stressing the source gridftp server too much (pads)
>> >> that it cannot handle a throttle of 8 . But at this configuration,
>> >> I
>> >> get low transfer performance. When doing direct transfers, I was
>> >> able
>> >> to get better transfer rates until i start coking out gpfs at 10k
>> >> stageins. My throttle for this configurations was 40 for both file
>> >> transfers and file operations.
>> >> 2010/12/2 Allan Espinosa <aespinosa at cs.uchicago.edu>:
>> >> > I have a bunch of 3rd party gridftp transfers. Swift reports
>> >> > around
>> >> > 10k jobs being in the vdl:stagein at a time. After a while i get
>> >> > a
>> >> > couple of these errors. Does it look like i'm stressing the
>> >> > gridftp
>> >> > servers? my throttle.transfers=8
>> >> > 2010-12-02 02:22:06,008-0600 DEBUG DelegatedFileTransferHandler
>> >> > Starting service on gsiftp://gpn-hus
>> >> > File
>> >> > transfer with resource local->r
>> >> > 2010-12-02 02:22:06,247-0600 DEBUG DelegatedFileTransferHandler
>> >> >        at
>> >> > esource.java:51)
>> >> >        at
>> >> > esource.java:34)
>> >> >        at
>> >> >        org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImp
>> >> >        at
>> >> >        org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(D
>> >> > eTransferHandler.java:352)
>> >> >        at
>> >> >        org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestin
>> >> > ngDelegatedFileTransferHandler.java:46)
>> >> >        at
>> >> > andler.java:489)
>> >> > refused
>> >> > rror code 1) [Nested exception message: Custom message:
>> >> > Unexpected
>> >> > reply: 451 ocurred during retrie
>> >> > org.globus.ftp.exception.DataChannelException: setPassive() must
>> >> > match
>> >> > store() and setActive() - ret
>> >> > rror code 2)
>> >> > match
>> >> > rror code 2)
>> >> >        at
>> >> >        org.globus.ftp.extended.GridFTPServerFacade.retrieve(GridFTPServerFacade.java:469)
>> >> >        at org.globus.ftp.FTPClient.put(FTPClient.java:1294)
>> >> >        at
>> >> >        at
>> >> >        at
>> >> >        at
>> >> > andler.java:489)
>> >> > message: Unexp
>> >> > : 451 ocurred during retrieve()
>> >> > match
>> >> > rror code 2)
>> >> > match
>> >> > rror code 2)
>> >> >        at
>> >> >        at
>> >> >        at
>> >> >        at
>> >> >        at
>> >> > andler.java:489)
>> >> >        at
>> >> >        at
>> >> >        at
>> >> >        org.globus.ftp.vanilla.TransferMonitor.run(TransferMonitor.java:195)
>> >> >        ... 1 more
>> Allan M. Espinosa <http://amespinosa.wordpress.com>
>> PhD student, Computer Science
>> University of Chicago <http://people.cs.uchicago.edu/~aespinosa>
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user mailing list
