[Swift-user] Montage wrapper error
Jonathan Monette
jon.monette at gmail.com
Tue Aug 3 23:29:22 CDT 2010
Ok. Let me know if you need more of my input files or configurations.
On 8/3/10 11:20 PM, Mihael Hategan wrote:
> Ok. I'll need to take a look at these.
> On Tue, 2010-08-03 at 23:15 -0500, Jonathan Monette wrote:
>> with use.provider.staging=true i get
>> Execution failed:
>> Exception in mProjectPP:
>> Arguments: [-X, raw_dir/2mass-atlas-990214n-j1210091.fits,
>> proj_dir/proj_2mass-atlas-990214n-j1210091.fits, template.hdr]
>> Host: teraport
>> Directory:
>> m101_montage-20100803-2312-ex8oc5ff/jobs/y/mProjectPP-yt0gtrvjTODO: outs
>> Caused by:
>> Job failed with an exit code of 254
>> and with that line commented out i get a script printed to the screen
>> saying it doesn't know what #!/BIN?BASH
>> Execution failed:
>> Could not initialize shared directory on teraport
>> Caused by:
>> org.globus.cog.abstraction.impl.file.FileResourceException:
>> org.globus.cog.karajan.workflow.service.ProtocolException: Unknown
>> command: #!/BIN/BASH
>> On 8/3/10 11:04 PM, Mihael Hategan wrote:
>>> Eh. I'll see if I can fix those.
>>> Though if you are using coasters, and given that I do think I fixed the
>>> existing issues, there is one more thing you could try:
>>> in swift.properties, at the end, say use.provider.staging=true
>>> Mihael
>>> On Tue, 2010-08-03 at 22:59 -0500, Jonathan Monette wrote:
>>>> <pool handle="teraport">
>>>> <execution provider="coaster" url="tp-login2.ci.uchicago.edu"
>>>> jobmanager="ssh:pbs" />
>>>> <filesystem provider="coaster" url="ssh://tp-login2.ci.uchicago.edu" />
>>>> <profile namespace="globus" key="maxtime">3000</profile>
>>>> <profile namespace="globus" key="workersPerNode">8</profile>
>>>> <profile namespace="globus" key="slots">1</profile>
>>>> <profile namespace="globus" key="nodeGranularity">1</profile>
>>>> <profile namespace="globus" key="maxNodes">10</profile>
>>>> <profile namespace="globus" key="queue">short</profile>
>>>> <profile namespace="karajan" key="jobThrottle">0.7</profile>
>>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>>> <filesystem provider="ssh" url="tp-login2.ci.uchicago.edu"/>
>>>> <workdirectory>/home/jonmon/Library/swift/work/teraport</workdirectory>
>>>> </pool>
>>>> here is the new sites entry. I tried running my code and got this error.
>>>> class
>>>> org.globus.cog.abstraction.impl.file.coaster.buffers.NIOChannelReadBuffer throws
>>>> exception in doStuff. Fix it!
>>>> java.lang.NullPointerException
>>>> at
>>>> org.globus.cog.abstraction.impl.file.coaster.commands.PutFileCommand.dataRead(PutFileCommand.java:79)
>>>> at
>>>> org.globus.cog.abstraction.impl.file.coaster.buffers.ReadBuffer.bufferRead(ReadBuffer.java:77)
>>>> at
>>>> org.globus.cog.abstraction.impl.file.coaster.buffers.NIOChannelReadBuffer.doStuff(NIOChannelReadBuffer.java:36)
>>>> at
>>>> org.globus.cog.abstraction.impl.file.coaster.buffers.Buffers.run(Buffers.java:122)
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user
