[Swift-user] Montage wrapper error
Mihael Hategan
hategan at mcs.anl.gov
Tue Aug 3 23:04:19 CDT 2010
Eh. I'll see if I can fix those.
Though if you are using coasters, and given that I do think I fixed the
existing issues, there is one more thing you could try:
in swift.properties, at the end, say use.provider.staging=true
Mihael
On Tue, 2010-08-03 at 22:59 -0500, Jonathan Monette wrote:
> <pool handle="teraport">
> <execution provider="coaster" url="tp-login2.ci.uchicago.edu"
> jobmanager="ssh:pbs" />
> <filesystem provider="coaster" url="ssh://tp-login2.ci.uchicago.edu" />
> <profile namespace="globus" key="maxtime">3000</profile>
> <profile namespace="globus" key="workersPerNode">8</profile>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="globus" key="nodeGranularity">1</profile>
> <profile namespace="globus" key="maxNodes">10</profile>
> <profile namespace="globus" key="queue">short</profile>
> <profile namespace="karajan" key="jobThrottle">0.7</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <filesystem provider="ssh" url="tp-login2.ci.uchicago.edu"/>
> <workdirectory>/home/jonmon/Library/swift/work/teraport</workdirectory>
> </pool>
> here is the new sites entry. I tried running my code and got this error.
> class
> org.globus.cog.abstraction.impl.file.coaster.buffers.NIOChannelReadBuffer throws
> exception in doStuff. Fix it!
> java.lang.NullPointerException
> at
> org.globus.cog.abstraction.impl.file.coaster.commands.PutFileCommand.dataRead(PutFileCommand.java:79)
> at
> org.globus.cog.abstraction.impl.file.coaster.buffers.ReadBuffer.bufferRead(ReadBuffer.java:77)
> at
> org.globus.cog.abstraction.impl.file.coaster.buffers.NIOChannelReadBuffer.doStuff(NIOChannelReadBuffer.java:36)
> at
> org.globus.cog.abstraction.impl.file.coaster.buffers.Buffers.run(Buffers.java:122)
More information about the Swift-user
