[Swift-user] Montage wrapper error
Jonathan Monette jon.monette at gmail.com
Tue Aug 3 22:49:56 CDT 2010
to use the coaster filesystem i should use local:pbs in the jobmanager?
On 8/3/10 10:44 PM, Mihael Hategan wrote:
> Ok. Maybe not. Looks like an SSH issue. Can you try the coaster fs
> provider instead?
> On Tue, 2010-08-03 at 22:41 -0500, Jonathan Monette wrote:
>> <pool handle="localhost">
>> <filesystem provider="local" />
>> <execution provider="local" />
>> <workdirectory>/home/jonmon/Library/Swift/work/localhost</workdirectory>
>> <profile namespace="karajan" key="jobThrottle">.05</profile>
>> </pool>
>> <pool handle="teraport">
>> <execution provider="coaster" url="tp-login2.ci.uchicago.edu"
>> jobmanager="ssh:pbs" />
>> <profile namespace="globus" key="maxtime">3000</profile>
>> <profile namespace="globus" key="workersPerNode">8</profile>
>> <profile namespace="globus" key="slots">1</profile>
>> <profile namespace="globus" key="nodeGranularity">1</profile>
>> <profile namespace="globus" key="maxNodes">10</profile>
>> <profile namespace="globus" key="queue">short</profile>
>> <profile namespace="karajan" key="jobThrottle">0.7</profile>
>> <profile namespace="karajan" key="initialScore">10000</profile>
>> <filesystem provider="ssh" url="tp-login2.ci.uchicago.edu"/>
>> <workdirectory>/home/jonmon/Library/swift/work/teraport</workdirectory>
>> </pool>
>> This is my sites file
>> On 8/3/10 10:40 PM, Mihael Hategan wrote:
>>> On the remote site there should be something called
>>> ~/.globus/coasters/coasters.log. It tends to contain useful information.
>>> As usual, the swift log also tends to contain useful information.
>>> However, Mike has mentioned some problems when using the coaster
>>> filesystem provider. In the effort to implement provider staging for
>>> coasters, that may have broke. Is that what you are using? (i.e. post
>>> sites.xml).
>>> Mihael
>>> On Tue, 2010-08-03 at 21:12 -0500, Jonathan Monette wrote:
>>>> Hello,
>>>>        Has anyone ever ran into this error:
>>>>        Failed to transfer wrapper log from
>>>> m101_montage-20100803-2101-4ihqvdv9/info/s on teraport
>>>> Execution failed:
>>>>        Exception in mProjectPP:
>>>> Arguments: [-X, raw_dir/2mass-atlas-990524n-j0320044.fits,
>>>> proj_dir/proj_2mass-atlas-990524n-j0320044.fits, template.hdr]
>>>> Host: teraport
>>>> Directory: m101_montage-20100803-2101-4ihqvdv9/jobs/s/mProjectPP-sz57orvj
>>>> stderr.txt:
>>>> stdout.txt:
>>>> Caused by:
>>>> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
>>>> Cannot determine the existence of the file
>>>> Caused by:
>>>>        The connection has been closed [Unnamed Channel]
>>>> Cleaning up...
>>>> Shutting down service at https://128.135.125.117:52276
>>>> Got channel MetaChannel: 1867624887[1293086287: {}] ->
>>>> GSSSChannel-11234326669(1)[1293086287: {}]
>>>> + Done
>>>> I am testing my wrappers to Montage on a larger scale and I keep getting
>>>> this error.  There is about 640 images but it only projects about 142
>>>> images before this error pops up.  If my run will help my run exists at
>>>> "/home/jonmon/Workspace/Swift/Montage/m101_j_4x4/runs/m101_montage_Aug-03-2010_21-01-09"
>>>> on the ci machines.  Any help is much appreciated.
Jon
Computers are incredibly fast, accurate, and stupid. Human beings are incredibly slow, inaccurate, and brilliant. Together they are powerful beyond imagination.
- Albert Einstein
More information about the Swift-user mailing list
