[Swift-user] Montage wrapper error
Mihael Hategan
hategan at mcs.anl.gov
Tue Aug 3 22:40:17 CDT 2010
On the remote site there should be something called
~/.globus/coasters/coasters.log. It tends to contain useful information.
As usual, the swift log also tends to contain useful information.
However, Mike has mentioned some problems when using the coaster
filesystem provider. In the effort to implement provider staging for
coasters, that may have broke. Is that what you are using? (i.e. post
sites.xml).
Mihael
On Tue, 2010-08-03 at 21:12 -0500, Jonathan Monette wrote:
> Hello,
> Has anyone ever ran into this error:
> Failed to transfer wrapper log from
> m101_montage-20100803-2101-4ihqvdv9/info/s on teraport
> Execution failed:
> Exception in mProjectPP:
> Arguments: [-X, raw_dir/2mass-atlas-990524n-j0320044.fits,
> proj_dir/proj_2mass-atlas-990524n-j0320044.fits, template.hdr]
> Host: teraport
> Directory: m101_montage-20100803-2101-4ihqvdv9/jobs/s/mProjectPP-sz57orvj
> stderr.txt:
> stdout.txt:
> Caused by:
> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
> Cannot determine the existence of the file
> Caused by:
> The connection has been closed [Unnamed Channel]
> Cleaning up...
> Shutting down service at https://128.135.125.117:52276
> Got channel MetaChannel: 1867624887[1293086287: {}] ->
> GSSSChannel-11234326669(1)[1293086287: {}]
> + Done
> I am testing my wrappers to Montage on a larger scale and I keep getting
> this error. There is about 640 images but it only projects about 142
> images before this error pops up. If my run will help my run exists at
> "/home/jonmon/Workspace/Swift/Montage/m101_j_4x4/runs/m101_montage_Aug-03-2010_21-01-09"
> on the ci machines. Any help is much appreciated.
More information about the Swift-user
