[Swift-user] Problems running example scripts
Mihael Hategan hategan at mcs.anl.gov
Thu Apr 1 17:28:53 CDT 2010
On Fri, 2010-04-02 at 00:17 +0200, Rickard Westerlund wrote:
> On Fri, Apr 2, 2010 at 12:03 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Right. Most of the examples will probably fail to work because the
> > standard unix executables don't exist in windows (unless you install
> > cygwin).
> I see. I have gnuwin installed and had tried to use the echo from
> there, but got the same error. Also tried to use DOS naming to avoid
> spaces. Guess I'll have to find a format that works.
Make sure you include the extension (i.e. echo.exe) in tc.data.
More information about the Swift-user mailing list
