[Swift-user] Problems running example scripts
Rickard Westerlund onionknigh at gmail.com
Thu Apr 1 17:17:46 CDT 2010
On Fri, Apr 2, 2010 at 12:03 AM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Right. Most of the examples will probably fail to work because the
> standard unix executables don't exist in windows (unless you install
> cygwin).
I see. I have gnuwin installed and had tried to use the echo from
there, but got the same error. Also tried to use DOS naming to avoid
spaces. Guess I'll have to find a format that works.
Thanks for your fast responses.
Rickard Westerlund
More information about the Swift-user mailing list
