[Swift-user] swift syntax question
Yi Zhu yizhu at uchicago.edu
Fri May 29 13:19:27 CDT 2009
In order to let swift write output to another directory rather than
currently running location, we can use  simple_mapper with location
parameter like
"<simple_mapper; location ="/mnt/s3", prefix="foobar", suffix=".txt">,
but if I want to use regexp_mapper, since there is no 'location'
parameter available for regexp_mapper,
(http://www.ci.uchicago.edu/swift/guides/userguide.php#mapper.simple_mapper)
how can i sort it out?
For example, In this case, every files with prefix "data" and suffix
".txt" at location "/mnt/testdata/1024Kdir" will be map to inputfiles[]
array, and for each running of loop, the  regexp_mapper will modify the
".txt" to 'swift xxx.swift' command), so how can i specify a output
location other than the default/current one?
(catfile t) catwords (messagefile f) {
     app {
         cat @filename(f) stdout=@filename(t);
messagefile inputfiles[]
<filesys_mapper;location="/mnt/testdata/1024Kdir",prefix="data"
,suffix=".txt">;
foreach f in inputfiles {
   catfile c<regexp_mapper;source=@f,match="(.*)txt",transform="\\1out">;
   c = catwords(f);
Many Thanks!
-Yi Zhu
More information about the Swift-user mailing list
