[Swift-user] first.swift issues
Michael Wilde
wilde at mcs.anl.gov
Fri May 29 13:31:39 CDT 2009
Alex, it sounds like you may be gettuing a different (old?) version of Java.
Can you try this on communicado.ci.uchicago.edu, and add this line to
the front of your .soft file:
+java-sun
- Mike
On 5/29/09 1:20 PM, Zhao Zhang wrote:
> Hi, Alex
> I tried the swift in your home dir, assuming that is the one you are
> using. It works for me.
> [zzhang at communicado amoore2]$ export PATH=/home/amoore2/swift-0.9/bin:$PATH
> [zzhang at communicado amoore2]$ which swift
> /home/amoore2/swift-0.9/bin/swift
> [zzhang at communicado amoore2]$ cd
> /home/zzhang/swift_coaster/cog/modules/swift/examples/
> [zzhang at communicado examples]$ swift first.swift
> Swift 0.9 swift-r2860 cog-r2388
> RunID: 20090529-1318-ada6yjqb
> Progress:
> Final status: Finished successfully:1
> zhao
> Alex Moore wrote:
>> Following the quick start guide to install swift on my CI account.
>> When I try execute: swift first.swift I get the following message:
>> "-Xmx256m not understood. Ignoring
>> log4j:ERROR Error occurred while converting date.
>> java.lan.IllegalArgumentExcepion: Illegal pattern character at
>> java.text.SimpleDateFormat.format(java.util.Date, ..."
>> It continues on for at least another page. This happens when I log in
>> on both login.ci.uchicago.edu and communicado.ci.uchicago.edu. I tried
>> deleting and reinstalling as well. I'm using swift-0.9
>> Also, the first.swift file in package is different from the one in the
>> swift tutorial. In swift-0.9, first.swift starts off with:
>> type messagefile;
>> app (messagefile t) greeting () {
>> echo "Hello, world!"......
>> While the swift tutorial has:
>> type messagefile;
>> app { echo "Hello, world!"......
>> I changed first.swift to what was listed in the swift tutorial, and I
>> got the same error message. Thank for your help.
>> -Alex Moore
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-user
More information about the Swift-user
