[Swift-user] possible coasters problem
Glen Hocky
hockyg at uchicago.edu
Tue Mar 31 17:40:50 CDT 2009
Hi Guys,
Do you think this is a problem with coasters or just the way i'm using it...
Glen
> Exception in runoops:
> Arguments: [input/fasta/T1ubq.fasta,
> teraportoutdir.100/T1ubq/T1ubq.ST50.TU200.0000.secseq,
> input/native/T1ubq.pdb,
> teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.pdt,
> teraportoutdir.100/T1ubq//ST50.TU200/0000/00/06/T1ubq.ST50.TU200.0000.0006.rmsd,
> 6, DEFAULT_INIT_TEMP_=_50, TEMP_UPDATE_INTERVAL_=_200,
> MAX_NUMBER_OF_ANNEALING_STEPS_=_0, KILL_TIME_=_55]
> Host: teraport
> Directory: oops-20090331-1701-fpuie7be/jobs/d/runoops-dsmccq8j
> stderr.txt:
> stdout.txt:
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> java.lang.IllegalArgumentException: No worker with id=1956306968
> at
> org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:85)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.CoasterQueueProcessor.run(CoasterQueueProcessor.java:71)
> Caused by: java.lang.IllegalArgumentException: No worker with
> id=1956306968
> at
> org.globus.cog.abstraction.coaster.service.job.manager.WorkerManager.getChannelContext(WorkerManager.java:483)
> at
> org.globus.cog.abstraction.coaster.service.job.manager.CoasterTaskHandler.submit(CoasterTaskHandler.java:78)
> ... 1 more
> Cleaning up...
> Shutting down service at https://128.135.125.118:55513
> Got channel MetaChannel: 22129174 -> GSSSChannel-null(1)
> - Done
> Command exited with non-zero status 2
> real 1628.27
> user 169.87
More information about the Swift-user
